To PPS or Not to PPS? Now, that is the question....
got_boosted
I need a turbo! >:(
Mar 3, 2006
608
Sacramento, CA
suprastanger507mgte;893442 said:
I'd say definitely go PPS if you can.
I drove Supras without any Ppower sterring = Horrible.
No PPS - its good
PPS = best feel.
I agree. When my car still had the 7M, the PPS wiring was damaged and wasn't working correctly. I fixed it when swapping the 2J, and I'm in love! My 88 N/A without PPS was too twitchy at high speeds, even with the pre-89 damper.
Collin
Jeff Lange
Administrator
4,927
20
Sunnyvale, CA
jefflange.ca
Poodles;897487 said:
sorry Jeff, but you're wrong...
Only difference is the pulley on the pump, the rack has the pressure control...
LOL. I'm blind, though I'm not completely wrong (although partially).
The pulley is not different. It is the same pulley from all the information I have. The pump however is different. The vane plates and everything internal is different between them, and they have different part numbers. The rack has more turns lock to lock (lower ratio). The VSV is on the rack though, NOT the pump. I'm sorry for that mistake. :(
Jeff
5
well, PPS came at the same time they deleted the steering stabilizer, which would explain the smaller pulley...
I know the pully is different depending on year for a fact though...
Jeff Lange
Administrator
4,927
20
Sunnyvale, CA
jefflange.ca
86.5 - 88 Pulleys: All the same
90 - 92 Pulleys: All the same
89 N/A Pulley: Same as 86.5 - 88 (Even if the car had the optional PPS -- Odd)
89 Turbo Pulley: Same as 90 - 92
Not sure what the reasoning behind this is.
Jeff
5
Yep, check the racks, the old racks have a dampner on them. They offset the removal of it with higher pressure from the pump...
