Tires?
darrick
63
des moines
Im in a position that i need some other supra owners perpectives. I need new tires and i dont know which brand and model i should go with. I thought about nitto. I wanted to see what most people say a good tire is on there supra.
Kevin
7mgte -> 7mgte swap done.
Apr 20, 2009
865
Windsor Ontario Canada
what kind of tire do u want? good grip in dry bad grip in wet? good autocross type tire? winter tires? summer only tires? all season tires? whats your budget?
darrick
63
des moines
Im only going to drive it in dry conditions so just in the summer time. I want a good gripping tire. Up to 500 dollars. There only going to be used on pavement.
SWD Fredester 3
674
baltimore maryland
Check out Tire Rack, they have a good selection of max performance summer tires listed with buyer feed back. I've been using Bridgestone Potenza SO3's.
Might change to Yokohama Advan's because of tire size availability.
darrick
63
des moines
Around 600 at the most, I will look around at all these tires you guys listed and make my decision. Thanks fellow supra owners.
toyotanos
What will we break today?
2,844
Coon Rapids, MN
honestabe;1468114 said:
Gaboon is right, the decent tires start at $175 each. Mine were in the $205-220 each range. If you can increase your budget, I'd recommend Goodyear Eagle F1 GS-D3's, Toyo T1R's, and Toyo R1R's. I run the first two currently.
Goodyear F1 GS-D3's FTW! Those tires were so sticky on my MR2, I just hope I can afford them again for my Supra! No direct Supra experience with them yet, but they will be going on my Supra.
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
Totally depends on your definition of "decent" or "good".
If you're going to track it every now and then, or if you're pushing 400+ to the wheels then sure, get the top of the line tire.
Otherwise, if you're using it as a daily, even just a summer only daily, you don't need the Michelin Primacy's or the P-Zero Pirelli's. You'll be fine with plenty of the $100-150 tires.
Of course size will play a huge role in this too. Using the stock size tires are cheaper than say an 18" size or a 17x8" tire.
I've been eyeing the BF Goodrich T/A KDW's for my next summer tire purchase...
