Timing???
7m2ner
Boosted MA70
Jan 26, 2006
82
Schaumburg, IL
i was wondering wat would be the best degree to set my timing, i have a pretty much stock set up, but it just seems like it idles a bit rough, and it has new plugs, so idk??? wat would you guys recomend???
koulee
497
If its idling rough, you should check to see if timing is at the stock 10 btdc. If it is, then you have other problems.
shaeff
Kurt is FTMFW x2!!!!
11
Around
just keep it stock...
i'm at 340 at the crank, and my timing is at 10* BTDC.
-shaeff
