Ok here it is. I'm still trying to get my damn timing right. My mechanic can only get to within 10degrees retard or over 10 advanced????. He's taken out the cam sensor about 4 times and adjusted it as well as he knows how. Is there some type of trick to get it to 10deg. advanced(stock setting). He's messed with the throttle position sensor, cam sensor, I can't figure it out either. Also during all this I had to replace my water temp sensor(ecu) and now my cold start warm up doesn't work. What the hells wrong with my car???? Also I had to put on a new cam sensor clip(mine fell to pieces). Thanks for any help.
