Supramk389;1306291 said:
			the head was machined and a 2mm stopper head gasket was installed done by Proven performance in CT. They should have known what they were doing. With crank pulley at 0 the cam gears appear to be off about half a tooth (to the right). Will this be ok?
It could be the rubber in the crank damper is twisted.  Do this:
- Remove the #1 plug and insert a small diameter wooden dowel about a foot long in the spark plug hole
- Rotate the crank to the zero index...pass it by a few inches.
- Note where the dowel peaks...that is true TDC for the piston
- If it peaks anywhere else besides the zero index, the crank damper is FUBAR and will need to be replaced
Depending on how much material was removed from the head/block vs what the stock HG thickness provides can have an effect too.
