throwing codes... tell me if i'm right...
Insidious Surmiser
Formerly 89jdm7m
May 12, 2006
2,172
Oceanfront
threw a 24, 31, and 34... i've checked for boost leaks and fixed all that i found... now, the afm has always had problems in the plug area (it's been loose, and the connector on the inside of the afm has been snapped before... i'm gonna go ahead and assume that I should replace the afm... since all of these codes could possibly be the afm, and i've had problems w/ it before... also, if this is the issue, how poorly will this make my car run, as opposed to if it was functioning propperly
Insidious Surmiser
Formerly 89jdm7m
May 12, 2006
2,172
Oceanfront
alright, will do :)... reason i say afm, is because i've had problems w/ it before, and i've ruled out almost every other posibility, but i'll go ahead and test it. thanks for the input
dallas
jetjock
creepy-ass cracka
9,439
Of the top of my head all those codes are AFM related and likely caused by the bad connector. I agree 100% with shaeff but since the connector has already been busted I'd replace it anyway even if the AFM is working.
