There is hope for your alignment.
87witmoreboost
Officially HKS'd
Aug 27, 2007
323
New Hampshire
Sent my car to be aligned today, post-lowering.
Car has RS*R Race Springs and I was told by many to order camber kits.
Alignment went perfect and was aligned to spec on stock adjusters.
ValgeKotkas
2,224
Over the pond
Well...my bolts are rusted and therefore stuck. No alignment for me (until I get new bushings :()
You are one lucky man I think...
themadhatter
760
Vegas
I have tanabe gf210 springs and even after an alinment the rear camber is still way off and nothing was frozen or rusted in the suspension
shaeff
Kurt is FTMFW x2!!!!
11
Around
Lots of people's cars aren't in that nice of shape, especially on the undersides. The tabs for the eccentric bolts tend to bend over, which is why everyone should clean them, bend them straight, and run a bead of weld behind each one to prevent it from happening again.;)
That, and if you go too low, it won't be good no matter what... I believe the lower transverse arm is to blame.
HommerSimpson
1,067
New Smyrna Beach Florida
I took a look before i compleatly modified mine... but you can enlongate (sp) that slot and gain some...on the lower arm...you would have to bend tab over and then weld tab on inside of the outer tab to push arm further in...
but its very dooable... so for those that want to fix just pop one bolt out and take a look ( 10 min job if not rusted )... you will see...
tsuper92
supra addict
Apr 7, 2005
1,376
mass
new hampshire car and the bolt's weren't frozen.you sir might want to go buy some lottery ticket's
fstlane88
Single time!!
South FL
Where did you go to get your alignment done, j/w?
