Theorettically... If my Heater VSV is closed......
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
I gots the vsv Kyle. Sorry forgot to call you. Was too excited looking at my pretty 3.0 liter hehe.
Anytime after 2:30 pm , you can swing by my place. Bring IJ as well. :)
Big Wang Bandit
You Can't Quit Me Baby
Feb 21, 2006
7,551
San Ramon, CA - 925!
IJ. said:
There is an amplifier in the Heater control that can die and no matter what you do with the VSV or controls it'll blow cold.
Care to expand? I am looking for both spectrums.
Thanks Moe! Ill stop by around 3 tomorrow if that is okay, I forgot I have it off untill 6!
Expand what?
If the Amp is blown you won't get hot air full stop amen ;)
You can wire the Heater Valve open or remove it totally and there will still be no hot air nada zip zero zilch not a skerrick nyt nothing sans heat cold even.
Ok the actuator is leaking internally.
Next thing to check is run the motor put your finger on the end of the vacc hose and have someone switch the heater on and off you should feel it suck/not suck.
Big Wang Bandit
Feb 21, 2006
7,551
Then I'll give it a shot tomorrow morning.
Let me just clarify, Have the hose coming from the heater valve and finder on the side that would go on the VSV or am I going backwards?
Then put one of these
over the end of the
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
The check valve coming from the diaphragm which controls the HCV, I'm pretty sure that's backwards.... it only works when facing the right direction and the way that it's on there no vacuum would ever hit the diaphragm.... unless the check valve is shot.
The little black and white thingy in the middle of the vacuum tubing.
CRE
Oct 24, 2005
3,485
Denver, CO
I'm still referring to something else... same area though and what IJ's saying should show if vacuum's not getting to the diaphragm.
