The Torqueless 1j!
ForcedInduction;1158981 said:
26 psi on pump gas?
I can't think he would ever try that. He loves his car too much to blow it up.
foreverpsycotic;1162531 said:
It is entirely possible, look at some evo guys doing 30psi on pump. Sure they have all that boost, but little to no timing.
I'm sure it's been done, but I doubt any of us that know better will be trying it. I do plan on going with a meth kit, but only to run 19psi a bit safer with my new pt67.
lilazni3uoy
AEM Powered
NoRCaL and SoCaL
hey sorry guess i have not checked this thread for days!yes jay is right, i don't want to blow up my car! hahaha, yes 507 rwhp, i made it with 10 gal 118octane the rest were 91 octane, it was a mix, there's no way i can make 507 on pump especially on 26 psi, i'm on mk4 550cc's i'm way maxing out my fuel setup for 507 rwhp, but i'm already going to wesbeech to buy a dual pump hanger, and 1000cc injectors, so now i can max out my turbo setup before i do anything else
It seems like the 1000cc injectors might be a bit of overkill, but I don't know what your long term goals are.
I can't remember what you're tuning with, but if its an SAFCII, then the 1000cc injectors might be a bit tooo much for it. Good luck, and I"m sure you know what you're doing.
lilazni3uoy
AEM Powered
NoRCaL and SoCaL
1000cc's i think will be fine, i will eventually go with a gt40r or a sp67, and i'm on aem, ditched the safc couple months ago got all the nice bells and whistles in this mofo hahaha, then maybe shooting for 700 rwhp, and hope that the 1jz will hold the power!
Sooo many people have said that before, and then it wasn't enough. It's like an uncureable addiction.
Zazzn
l33t M0derat0r (On some other forum) n00blet here
7
Toronto/SF Bay area
wow just saw this, awesome man FINALLY people are starting to dyno 1jz's with the cam's that I got us...
It looks like they are perfect for you since you rev to just pass 7 and that's where they start to dip.. Just like on my twin k26's...
I think I'm going to do a GB on BC 1jz cams which will have a larger profile for those who want to rev a little higher.
Awesome numbers man, looks real good.. I maxed out my 550's and one walbro at 523, and had to turn down the boost form 23 as I dind't want to blow up the car ;)
lilazni3uoy
AEM Powered
NoRCaL and SoCaL
Grimsta;1178830 said:
Sweet man, what was your tune to at Motoring J when I saw you last?
last time you saw it at moring j it was only 356, rwhp @ 18 psi stock motor just 35r and fuel
yes they are great!greatly appreciate what you have done for the community with the crower cams!, John Reed tried to tune the car at 26 psi but it leans out at the top end around 12ish, he turned it down to about 23 psi, and only made roughly 507 here in sacramento, and 510 in vegas i need more fuel!
T701jz
3M ENGINEER - R.&.D
Jul 23, 2005
657
Santa Clarita Ca.
Very nice #'s Erick!!
Just finish rebuilding the bottom and I'm looking forward to see my dyno. I would replace those bearings if you're looking for more power.
noel
