The 7M Stinger Thread
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
Thanks Figgie, I'll check it out. I have a diode laying around, and I can see how much resistance is on that one so I can see if it's about the same. that should give me a vague idea if my wiring is doing the trick, right?
IJ, the ECU doesn't have a gauge or button for an ignition event (that I know of), but I can see that the injector signal is being sent, and the software is setup as Aaron's is. I held the #1 plug wire to a ground, and moved the CPS by hand and noticed there was no spark, but I could hear the injectors. I'm going to source a working ignitor (soon i hope) so i can see if thats the problem.
BTW, the CPS is getting a signal to the ECU and seems to be accurate, but its the same crappy one that I've re-wired twice, is there any chance that this could be part of the problem, or is the CPS's job done after it gets the signal to the ECU? I don't think its related, but just thought I'd mention it.
figgie
Twin Cities, Minnesot-ah
hottscennessey
for your question. No. The timing is what dictates when the fuel gets injected and when the ignition gets lit. Some ECU can control when the injector starts and stops. The ignition timing is what dictates when the spark event happens.
quick q
Did you find a base map to start from?
Otherwise
http://www.enginemanagement.com.au/showmap.php?id=41
for the 1jz. Yes I know the stock is 1jz is seq. This makes it wastefire. the only thing I would do is knock the dwell down to 2.125ms instead of the 3.5ms as the 7m coils do not require that much dwell.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
Okay, great. I was hoping the problem could still be ignitor, as that would probably be the simple fix.
I got the basmap from Aaron, so the dwell should be fine, but I'll definately try it out.
Q: The is normally sensing a 5v signal from the ECU, correct? It there any way to tell how many v's the Stinger is putting out?
I tried setting my multimeter as a voltometer, and connected it to a ground, and the IGtA wire, but I saw almost nothing, a few volts run through when I turned the igntion switch on, but nothing when I was cranking (yes, the stinger was getting an RPM signal). Am I missing something here or should I be seeing possitive voltage spikes/drops when I do this?
I got a CPS from a fellow supramania member today, I'll plug that in and see if that changes anything (I know it probably wont, but you never know).
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
With the stock ecu no spark will result in no injection. I dunno much about the stinger but I'm assuming it doesn't require IGf from the igniter. As for IGt you should be measuring it referenced to +12. Measuring it referenced to ground won't get you anything because IGt is an active low signal ie; it is ground.
The coil packs are a type of transformer. They have a primary winding and a secondary winding. The secondary winding is connected to the spark plugs while the primary is connected to the igniter. It's the primary we're concerned with in this case. It's nothing more than a coil of wire. One side of the coil is connected to 12 volts when the key is on and the other side is connected to the igniter. The igniter provides a ground to turn the coil on. It's when the coil is turned back off the spark occurs. To measure IGt going into the ignter you should connect one lead of your meter to 12 volts and the other to IGt. An led is another one way to monitor IGt when cranking. You can use a 12 volt test light across the coil pack primary to check the output of the igniter.
bigaaron
4,692
Pomona, CA
www.driftmotion.com
The stinger has a 5v logic level output that is compatible with the 7m ignitor. Make sure the standalone is set to falling edge for the trigger. I would put my money on a wiring mistake causing the problem. The ignitor is easy enough to test, and it works independently of the fuel injectors on the stinger. If you hear injectors clicking and the tach works when you crank it, then there should be ignitor outputs working from the Stinger also. If you can't figure it out then I could make that diode circuit up and label the wires, or you could go with an aftermarket ignition like a MSD DIS-4.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
Thanks for the info JJ
Aaron, you're right, I can't understand it being either the wiring or the ignitor, there is nothing else that really fits into the equation. I'll give it a few more days, and if I can't figure it out then I'll shoot you a PM for that circuit ;) I really appreciate it.
Aaron: Dis-6?
Hott: Time to strip it all out and start again from scratch, you've missed something.
On average there are 400 odd connections/steps in fitting a standalone missing ANY single one will stop things dead ;)
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
No problem. Usually when someone needs help with aftermarket stuff I'll chase down an online manual and study it but since Aaron has such a handle on this gadget I didn't see a need to do it. I'm sure with his help you'll get it figured out. I agree it sounds like a wiring issue.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
Progress.. I replaced the CPS and the stock tach moves, and when I stop cranking there is actually a backfire, and it sounds like it wants to start. Then my battery died.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
Just thought I'd update here again, No I couldn't get the car to start. Yes I know one reason why. Wether this is the only reason it wont start.. I dont know (but I hope!).
I am getting a spark from the coils for wire 1+6, 5+2. I am not getting a spark from the coil for 3+4. This is because in my harness I made for the IS300 coils, the trigger wire for the 3+4 coil is grounding out. I narrowed it down to the harness, so this should not be a problem to correct. I'll update after I get the time to re-wire.
I also snapped a wire off my harness side CPS connector, luckily I grabbed that conector off a supra at the junkyard 2 summers ago.. I don't even know why I did it, but I'm happy I did!
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
blah, getting spark to all cylenders, I can't get this thing to start. I'm getting backfires... one gave me 19.2 PSI of positive manifold pressure.. that worries me. Ignition timing off? I've played with the CPS like crazy.
figgie
you have something set incorrectly
backfire means the ignition event is happening after the exhaust valve opens. Try to set the CPS how you normally would using the TSRM.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
Figgie, thats how I orignially set it, as per TSRM. Is there a different way? Maybe I also screwed up the wires to the coils when I was doing the IS300 mod.. I'll have to look up the wiring diagram.
Off the top of my head, I believe I have the black wire going to the 1+6 coil, the green wire going to the 3+4 coil, and the white wire going to the 2+5 coil, and then the "ground" wire going to all of them, of course. Does anyone happen to know if thats right?
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
Yea, I'm still on the 7M coils, I just have to use that harness that I already hacked up.
Yea, its the 12v wire to the coils, I just called it "ground" because I couldn't remember.
figgie
ummm
if i am reading the schematic right
from ignitor to coils
it is
Black-Orange (goes to positive fused)
Light Blue - Red
Light Blue Yellow
Yellow
