temp gauge help
Boosted516
Supramano
Apr 13, 2008
475
Long Island, NY
My temperature gauge just stopped working, i took off my accordion hose and afm to find a boost leak so when i put everything back it wasnt working. What could i have done to make it stop working?
jetjock
creepy-ass cracka
9,439
The sender is nearby, located behind the power steering tank on the engine side of the thermostat housing. Properly called the water outlet housing. It's remotely possible you disturbed it. If you find it plugged in unplug it and momentarily ground the wire to the engine with the key on while someone watches the gage. It should go high. If it does the sender is bad.
Bill UK
90 Supra Turbo 14 psi
Aug 11, 2006
56
UK
There you go, Oil sender unit as supramk3man said, temperature sender unit coming up shortly.
Who
Bill UK;1048841 said:
Thanks supramk3man copy/paste went tits up.
Ok, according to that pic. The coolant intrument temp guage sensor is before the thermostat. My point being that the temp gauge is reading the temp of the coolant after it leaves the radiator and goes through the engine block before the thermostat. The reason I ask is because I thought I had read some posts where the temp gauge on the 7m was crap because it was reading the temperature in the radiator and not the true temp in the engine block.
Am I making any sense:aigo:
Great pic by the way I am saving that one to my files.
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
the wire thats lose thats hanging down there. duhh
it looks like the coolant temp sensor one, only its notched on one side so it slips on...
is it honestly that hard to figure out where wires go on a supra???
Boosted516
Supramano
Apr 13, 2008
475
Long Island, NY
yes its that hard if i dont see any wire in the first place.
