Tein HR Coilovers
supramk3man
414
kentucky
does any one have the Tein HR coilovers are their car. If so how do they work as far as a dd. I have sreached and found no info on the HR plenty on the SS and Flex. I have a set of the HR i could use but i don't want to put them to have to take the back off. If they are only going to bance you to death or mess up the ride of the car. Also where is a good setting to have the springs adjusted to.
gofastgeorge
944
Texas
All TEIN products are good, unless they are worn out.........
TEIN-USA sells repacement cartriges for them if they are,
if you can get that set cheap enough.
http://www.tein.com/
They are not like the chinese junk that has no support in this country.
The spring adjustment just sets your ride height, nothing more.
black91turbo
Formerly black87turbo
Apr 27, 2006
1,064
Jacksonville, FL
I have them on my car....I think the ride is great as long as you have new or good condition motor mounts. I have mine adjusted about 11 notches from the bottom in the back and about 9 in the front. It is ceratinly stiffer than stock and even stiffer than eibachs. I like mine though... If you go too low (below 9 notches) your Downpipe will suffer. Ask me how I know..... Also, you will hear some extra noises when you go over bumps but I was told that it is normal as long as everything is tightened to spec...
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
Just wondering.. What does motor mounts have to do with suspension?
