T3/T4
88MK3
117
Phoenix,AZ
Here are some pics of what i got so far.I have the CT26 to T3 adaptor with 38mm wastegate flange. Its a close fit but it does fit. Just need a wastegate, Some an fittings and steel lines, then a custom 3" exhaust. As well as some new gauges and a turbo timer. Eventually i will build the motor to hold the 22psi the Garrett T3/T4 can put out :bigthumb: But 8psi will do for now
P.S. Im selling my new ebay manifold for $200 shipped
BosoMKII
497
NorCal
What are the specs on that turbo? Looks a lot like the 60-1 I had. If so, that turbo is going to be bored at 8psi ;) Wait until you get her up into the efficancy range! :naughty:
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,779
13
Long Island, Ny
is the the manifold adaptor thats on ebay advertised for an MR2? with the wastegateport in the side? like teh one in the thread i made about it??
Kai
That Limey Bastard
Mmm - Garrett T3 :)
Those were stock on the Ford Escort RS Turbo's - 1.6 litre CVH engine running insaaaaaane boost....
Also came on the Sierra Cosworth until '93, and the Escort Turbo until '93/'94 shen they changed to the Garrett T2.
Loads of parts available for them here. They're pretty cheap for a rebuilt unit too - talking about £350 for a decent one with a 360* thrust bearing and a -31 actuator.
Used to have one a Fiesta RS Turbo yeaaaars back - with a 2.0 litre blueprinted Zetec, was running Weber Alpha management with a T3 - iirc, it was 22psi of boost. 7.1:1 Mahle pistons and ARP rods meant it was good for 8000rpm and 380bhp :D
Stretch
Tallest MK3 driver ever!!
Toronto, Ontario
And why aren't you using your brand new ebay manifold instead of the stocker? You could have just gotten a T4->T3 adaptor for it and been golden...
eric
88MK3
117
Phoenix,AZ
Its in just need to finish my oil drain line and water line. As soon as my wastegate shows up ill take it to phoenix turbos to have my custom 3" downpipe made. Ill keep you posted
88MK3
117
Phoenix,AZ
Ok got my 38mm wastegate,type-s style bov, and manual boost controller. Here are some pics.All water and oil feed lines are done except i need one 45 degree -10 fitting to connect the drain. I also remounted the stock intercooler and oil cooler after some extensive cleaning. Now its off to Phoenix Turbos to have my down pipe and wastegate pipe made. Almost done:biglaugh: :biglaugh:
P.S. Dont mind the stock bov soon to be replaced
88MK3
117
Phoenix,AZ
No I havent drivin it yet. Need my downpipe made and a wastegate pipe to move it down cause it hits the manifold. Its a T3/T4 60mm. It has a 4 bolt exhaust side. The downpipe is gonna be a 3" maderal bent and tig welded one. Its gonna cost me about $350
