T3/T04E Turbo application...
ggeiss240sx
82
Laramie, WY
I have a Garrett T3/T04E turbo that I used for my s14 240sx and it worked great. I was just wondering if this would be a good turbo to use on the 7m or would the exhaust housing be too small?
-60 trim T04E compressor wheel with a max flow rate of 53 lb/min
-0.60 AR T04E compressor housing
Thanks much!
Timmer
34
Canada
As IHI said, what's is the exh housing a/r and exh wheel trim. That cold side should flow over 400 whp at 20~ lbs, with a .82 a/r and large trim wheel iirc..
Sorry I just made the assumption that it was speced for a 2 litre it would have a smallish wheel/tight AR to go with that Compressor. (should really have waited for GG to post more info)
Timmer
34
Canada
ggeiss240sx said:
Sorry it doesnt even say the size on the exhaust housing, it roughly half the size of the compressor, or the average t3 size.
Hard to say, most likely it's a .48 if it was purchased for a 4 cyl setup in the first place.
