SUPRADAN's REBUILD/SWAP/RESTORATION
supradan22
NA->TER
May 20, 2005
915
ORLANDO FL
:biglaugh: ill try things have been going along pretty well I need to send my stuff to a machine shop as soon as i get my hands on a new crank.
supradan22
NA->TER
May 20, 2005
915
ORLANDO FL
Well tore apart the JDM TYTE engine to find out its in great shape never had a BHG so the surfaces are in great shape along with the cylinders very happy about that.
A little bit of rust that can be taken care of.
The damage from a spun bearing
The damage from a bad oil pump
Now its off to the machine shop
supra90turbo
shaeff is FTMFW!
MA, 01440
That's why I'm building my 7m block up, and not the 6m.
I figured the 6m block will make a good coffee table, heavy one at that. lol
supradan22
NA->TER
May 20, 2005
915
ORLANDO FL
Well looks like I didnt have a 6m crank in that block I tore apart never seen a 7m a 6m crank together. I figured it was a 6m crank because the block had the pre 89 mounts on it, It was also a Jdm motor that came out of Rays supra so who knows.
supradan22
NA->TER
May 20, 2005
915
ORLANDO FL
Well here are the new pics finnaly got the pics of the motor back from the machine shop.
So nice to see clean cylinders
pics of the new pistions on the refurbished rod
had my crank cut 0.10
More pics soon after it gets assembled.
IHI-RHC7
"The Boss"
Oregon
Explain to your machinest that you are using a try metal head gasket, and that they need to actually surface the deck of your block.
rakkasan
Currahee!!
Fort Campbell, KY
I agree, that looks far to pitted to put a MHG on. That's enough to bite into the MHG & cause a BHG. Thake it back & have it cut some more before you go any further.
supradan22
NA->TER
May 20, 2005
915
ORLANDO FL
Well havent really had much time to work on it till now that school is almost out. But this past week end got my turbo harness and ecu and finally assembled the bottom end next week end head gets set on it again and dropped in the suppie.
