SuprA70 engine build II***sneak peak***
Nick Stonawski
403
Manhattan Beach
soapra said:
Here is the original pictures of the block when Urbano and the owner on the top left were preping the engine to be installed.
Here is us now with the same block being silly! :icon_razz Block No. 6050772
bahahah. that was fun! :biglaugh: glad it went from one of the SoCal Mike's to another. keep it in the family. :)
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
well ive heard of 3 stories. 1 about sabotage, 1 of just dislike of the platform, and 1 that your 7m blew up even though it was all in check. so im guessing number 3?
SuprA70
SF.com 'Grounded' Champ
Rodknock was what killed my 7M. I was even on the verge of installing the Stinger to really see what my motor was capable of. Sadly, I didn't get the chance. I don't hate the platform, maybe I'll build another one someday. The opportunity presented itself where I was able to get a built block (overbored 2.6 with 9:1 compression), so I just went from there. Most of the mods I was putting on, like the standalone, made the swap easy. The ct26 manifold by Driftmotion let me keep my 60-1 and the BIC divorced downpipe also. Right now, I'm still in the process of break-in. In a few weeks, I should be ready to put some numbers down.
One thing for sure, this car is FUN again :biglaugh:
SuprA70
Finally got a baseline dyno on this new motor. Not too bad.
The 1JZ is running only on the Stinger standalone @ 8 psi, the 7M off stock ECU + VPC + AFC Neo @ 16 psi.
Identical turbo setup (60-1 ct26, BIC DDP), 550cc injectors. Both motors were complete rebuilds.
A couple hundred more miles then up goes the boost. Stay tuned :biglaugh:
spinningheadboy
Ich bin gegan alles
idaho
The car looks great. The 1JZ install looks very clean. Love to the see the car in person someday. I'm very interested in the numbers you will make with some real boost. I keep thinking that the DM CT manifold set-up is a very reasonable way to go for little cash.
cwd
Zazzn
l33t M0derat0r (On some other forum) n00blet here
7
Toronto/SF Bay area
so you are running a 60-1 on the 1jz 1jz and making all that power and the other dyno was a 7m at 16 psi?
I take it the 1jz was 294?
SuprA70
The smoother graph is indeed the 1JZ... still running only ~8psi on the stock wastegate. I'm just about ready to turn it up... just waiting to find the time to get the boost controller set up.
SD2JZA70
HardTunedMotorsports
San Marcos, CA
Do you know what killed the rod bearings in your 7M? Was it oiling related or a tuning issue causing the engine to detonate, thus killing the rod bearings?
SuprA70
Most likely oiling. Constantly keeping my 7M always in the high RPMs couldn't have been good either. I've never detonated the engine, so that's definitely not the culprit. At this point, I don't really know yet. I'm having trouble finding the motivation to tear into the engine as it's just sitting in the backyard. Been too busy driving the car again :biglaugh:
