supra wont start
karlmk3
336
thornton
ok so i am looking at buying a 1987 supra 7mgte head body are fine the car will not start it turns over and it will start on starter fluid the guy said that the dealership told him it was an ignition part the car will only run as long as u spray starter fluid so is it something with the gas or any help greatly appreciated o and the speedomiter dosent work
radiod
1,342
Abbotsford, BC
How much are they asking? If it's not running off the gas that is in there it could be contaminated gas, but even trying to run contaminated gas can really do a number on your pump and/or injectors...I personally wouldn't touch it unless you planning on dropping some cash and effort in to the car right off the bat.
karlmk3
336
thornton
he wants 1100 i am also looking at a 89 supra with blown head gasket but if i get that i am doint the 1jz the 89 is 1000 both no rust both have good body just one is an hour and a half away the other 30 min he saying something with ignition u think it something with the gas the fuel pump was just replaced on it ?
dumbo
1,913
Albera, Too Far North
I would try jumping the fp and b+(Check the the tsrm, I'm at work, but i'm pretty sure its those two) See if the fuel pump works, and try to start it with those jumped. Also check for codes(TSRM again)
Its deffinetly not ignition if it runs with starter fluid. And stop using it cause your not getting anywhere and just wiping your cylinder walls clean(If it is Ether your using).
radiod
1,342
Abbotsford, BC
It really comes down to what you're aiming for then really. Are you wanting to stick with the 7M or are you going to swap in the 1JZ? Each has it's own benefits and drawbacks, both can be (probably will be) a lot of time and money and if you plan on doing your own work, blood and sweat (and don't think you won't bleed, you will!).
On a sidenote:
Punctuation is your friend.
run on paragraphs like this are very hard to read they dont seperate the points well a lot of people wont even bother to read them especially if you dont put in periods apostraphes and other things that are necessary for the english language to make sense
Just a thought ;)
karlmk3
336
thornton
ok thank you sorry about that. what i am looking to do is put in the 1jz it seems like alot of ppl realy like this moter. i will be doing the work myself with the help of my gf dad and her brother. they have there own shop and will be repainting the car also they are pro and have done alot of rebuild. his paint jobs are amazing. right now it just trying to find the car i was hoping that the 7mgte one i was looking at the 87 wouldnt be to much of a pain but it seem like it will turn out to be just as much work if not more. i would still be taking out the moter in both just so i can paint the engine bay as well. i cant do half asked honda work lol
radiod
1,342
Abbotsford, BC
Honestly if you're just going to be dropping an engine in get the one that is the better shell, interior/exterior, etc. If they're pretty equal, get real picky, find which interior color(s) you like more (since you'll be painting it too).
karlmk3
336
thornton
they both sold dang ok well back to trying to find another mk3 it is the only car i will buy ill just have to keep looking for one i quess
