Supra Vs Supra (7M vs 1JZ) RESULTS IN VIDEO Pg.21 Post #209
87supraguy
808
Tucson, az
Turbo Habanero;1796331 said:
I think i will have the same issue I don't exactly have good tires George lol. I was think the turbo Lag would help you with traction
i'm not saying you have the best tires it's just i have no traction running through the gears period and the lag is only when starting in first gear, after that its Traction control please!!!!
Plau000;1796337 said:
Jorge, my MKIV tires won't help you much. They have less tread than your sawblades... You don't drive around town on slicks so forget racing on them.
miguel... yes they would. they are considerably wider the sawblades. hahahaha the wider the tire more surface you can get traction from and actually i did have street slick remember M/T street tires and i was was cruising around in them a short while but sold them to Billy cause i needed cash.
Turbo Habanero
4,229
Tucson,AZ
87supraguy;1796457 said:
can't it wait till next year? it's been 3 yrs.... she aint going anywhere!
LMAO George
Just swapped out my Driver side door panel for the one George gave me looks 100% bettter. now i have no crack anywhere :) thankyou sir
Turbo Habanero
4,229
Tucson,AZ
Woke up at 5am today and decided to go detail my interior and take another bottle of purple power to my engine also welded up my stock exhaust so I can get through emissions also cleaned up some of the wiring in my harness.
87supraguy
808
Tucson, az
Got my injectors put it last night and hooked up the AEM. And with the time car is 10xs better! Going to psi later today for fine tuning since the injectors are now.
87supraguy
808
Tucson, az
i got half of my suspension swapped over (rears only, fronts will be installed today). KYB GR-2 struts (not the greatest and probably won't last much longer cause they're crap!!!) but it's better than the deactivated tems i had. update i fixed my coolant leak by my exhaust but somehow i created a new leak by the heater core on the intake side.....FML!!!
today:
install front suspension
walbro FP
fix new leak
radiator flush and new toyota red
install my new auto radio antenna
some how i need to have my exhaust rehung it's scraping every where.
Turbo Habanero
4,229
Tucson,AZ
So i attempted to get my old turbo elbow off but no luck my ass is to weak lol.
So i ended up taking my intercooler off to clean it out had some oil build up on the hot side.
I won't be able to run this Sunday but hopefully i will still make it to IFO to spectate :)
IndigoMKII
2,181
Madison, Virginia
Try loosening the elbow with your hands this time instead of your ass. On a side note I put anti-seize on mine so hopefully I won't need to hurt myself getting them off.
Turbo Habanero
4,229
Tucson,AZ
87supraguy;1797209 said:
i hate you.... :)
Not my fault lol. It's still a possible but i'm not sure yet waiting for Albert to get back to me going with Miguel to phoenix tomorrow and might be able to get the turbo and then get the car together by tomorrow night.
Then i have to drive a whole lot to break in turbo and do emissions by Friday or get temp plate
87supraguy
808
Tucson, az
i have a plate you can use tags till '12 i have my new custom plate on.... Jk i don't want to get in trouble. try to make it hapen so that you can atleast show up in your car to the meet.
Turbo Habanero
4,229
Tucson,AZ
Well we both have white 89's LOL.
Albert;1797245 said:
Working on the housing. Gonna try and get it done before tomorrow
That would be awesome
87supraguy
808
Tucson, az
hmmmm you do have a point.... you know you now no longer stand a chance. i finally put my JZ Powred plate on.... instant 1000HP give or take of course
