Supra Turbo BOV
steven89
892
Houston, TX
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
That's exactly how it's suppost to work ;). And when you switch to an actual Blow Off Valve (the stock is a bypass valve of sorts) it vents the air directly into the atmospher, causing the engine to load up on fuel because it thinks it's getting that extra bypassed air put back into the engine, this causes it to backfire and even stall on some 7M's ;).
GotToyota?
Dedicated Member
Apr 6, 2005
1,639
Texas Motor Speedway
Isn't that why many people keep the stock BOV in addition to the aftermarket BOV?
-Matt
MKIIINA
Destroyer of Turbos
Plano, TX
HellsLegion said:
No, Thats because they are lazy.
you forgot cheap too! the stock bov is only good till around 10 psi or less and with worn out parts and however many miles its probibly blown already
whudafux
Formerly dcrusupra
Jan 5, 2006
1,034
Cullowhee, NC
Is this what u are looking for?
TiAL BOV and stock BOV
Brady
262
Bay Area
www.nbhq.net
does this than have an adverse affect on gas mileage?
veedubin
Official SM Decals
IJ. said:
Running 2 BOV's seems a little pointless....... I think..... the stocker if it is weak will open before you hit your desired boost level (as mine does:icon_evil ) then by the time the other one kicks open, there is nothing more to vent, as the stocker already bled it off.. am i wrong??? BTW where is a good place to get a cheap BOV
kwnate
Lurker
Jul 10, 2005
2,725
None of your fucking business
When running high boost one BOV might not have the capacity to vent the air and will cause compressor surge. That is why IJ has two.
Does that Tial function properly with no vacuum source? Seems like it would leak boost.
whudafux
Formerly dcrusupra
Jan 5, 2006
1,034
Cullowhee, NC
Actually it doesn't leak. It sounds great on the car. I've capped it off better since then. That was just a picture from the first test drive. Now it holds 8 psi all the way til redline. It held 10 psi the first test drive until my 3000 to TB coupler exploded. Then I put it back to stock boost.
