Supra Head Flow (5M,7M,1JZ,2JZGE,2JZGTE)
ma71supraturbo
Redding, CA
www.geocities.com
Stock heads:
Ported:
Note -- I need good data on the 1JZ. The current graph is an approximation based on the idea that the 1JZ flows 90% of the 2JZGTE intake, and 88% of the 2JZGTE exhaust. I got this data from a post by Erin Carpenter on Supraforums where he tested a stock 1JZ intake port at 215cfm at .4" lift and 133cfm for the exhaust (he tested a 2JZGTE at 238cfm intake and 154cfm exhaust). Its quite possible that the 1JZ flows as well as the 2JZ up to a certain lift, and then stalls earlier (more like the 7m). The rest of the engines are about as accurate as one could expect -- averaging data from 3-8 people/engine.
ma71supraturbo
Redding, CA
www.geocities.com
Raw numbers (pressure is at 28" H20 unless otherwise noted -- you can convert from another pressure by multiplying by sqrt(28/x) where x is the other pressure in inches of H20):
5MGE
Bruce Hilsabeck (tested at 25" H20)
Intake: (lift in inches, stock cfm, ported cfm)
0.1 52 63
0.2 109 114
0.3 137 153
0.4 149 182
0.5 158 199
Exhaust: (lift in inches, stock cfm, ported cfm)
0.1 40 52
0.2 66 101
0.3 101 126
0.4 119 141
0.5 126 147
JT (Tested at 10" H20)
0.039 13.7 14.5
0.079 27.3 27.7
0.118 40.3 40.7
0.157 52 43.3
0.197 63.2 66.8
0.236 73 78.9
0.276 78.7 89.7
0.315 81.8 99.1
0.354 85.8 106.1
0.394 89.3 111.5
0.433 92.4 115.7
0.472 93.3 117.5
0.512 95.1 117.9
Exhaust: (lift in inches, stock cfm)
0.039 10.7
0.079 22.3
0.118 33.7
0.157 44
0.197 56.5
0.236 67.3
0.276 76.2
0.315 80
0.354 83.9
0.394 85.3
0.433 86.8
0.472 87.8
0.512 88.2
MARK5mgte (tested at unknown pressure on homemade flowbench)
Intake: (lift in inches, stock cfm, ported +1mm OS valve cfm)
0.4 185 252
ma71supraturbo
Redding, CA
www.geocities.com
7MG
Stock 7m Intake:
lift(in)___Defiant7m___iNvis7M ('89)___T72mk3 ('89)___chevyeater1 ('90 #6 casting)
0__________0___________0_______________0_____________0
0.05_______ ___________37.8____________30.8___________
0.1________77.4________81______________67.3__________
0.15_______113.9_______118.5___________ ______________
0.2________141.4_______149_____________139.1_________158
0.25_______162.8_______166.8___________ ______________183
0.3________176_________184.8___________179.7_________198
0.35_______179.6_______190.7___________ ______________205
0.4________179.6_______193.7___________190.1_________210
0.45_______180_________ _______________ ______________210
0.5________180_________ _______________190.1__________
Stock 7m Exhaust:
llift(in)___Defiant7m___iNvis7M ('89)___T72mk3 ('89)___chevyeater1 ('90 #6 casting)
0.05_______ ___________30.2____________29.9___________
0.1________60.4________65______________62.1__________
0.15_______93__________84.5____________ ______________
0.2________112.9_______106_____________112.7_________135
0.25_______123.2_______116.9___________ ______________148
0.3________127.8_______121.4___________130.8_________155
0.35_______130.7_______126_____________ ______________156
0.4________133.2_______129_____________137.7_________158
0.45_______133.2_______ _______________ ______________160
0.5________133_________ _______________140.4__________162
Defiant7m stock vs street port (stock valves, cut valve guides) vs race port (2JZ valves, cut valve guides, "big port" #12 casting I believe, and lots of porting)
Intake:
lift(in)___Stock___Street___Race
0.1________77.4____80.4_____80.8
0.15_______113.9___122.4____121.7
0.2________141.4___159.9____152.6
0.25_______162.8___187.8____181
0.3________176_____202.4____201.3
0.35_______179.6___211.2____211.8
0.4________179.6___216.5____222.4
0.45_______180_____220______231.8
0.5________180_____220______239.1
Exhaust:
0.1________60.4____76.3_____76.3
0.15_______93______103.4____108
0.2________112.9___121______135.2
0.25_______123.2___131______150.3
0.3________127.8___139.4____163.8
0.35_______130.7___143.1____167.6
0.4________133.2___149.5____171.8
0.45_______133.2___155______174
0.5________133_____155______178
T72mk3 ('89) stock vs ported (stock valve)
Intake:
Lift(in)___Stock___Ported
0__________0_______0
0.05_______30.8____39.3
0.1________67.3____78.5
0.2________139.1___166.4
0.3________179.7___213.9
0.4________190.1___228.8
0.5________190.1___234.7
Exhaust:
0.05_______29.9____39
0.1________62.1____75.7
0.2________112.7___131.6
0.3________130.8___156.5
0.4________137.7___172.8
0.5________140.4___176
MADSUPRA88 Ported (stock valve):
Lift Intake
500 243
400 231
300 216
200 188
100 114
Lift Exhaust
500 193
400 186
300 172
200 142
100 80
ma71supraturbo
Redding, CA
www.geocities.com
2JZGE
Intake (stock):
Lift(in)_gianttomato_SuperRunner_Headgames
0.05_____39.32_______ ___________
0.1______82.49_______89.65_______89
0.15_____129.68______ ___________
0.2______163.32______158.27______130.4
0.25_____191.43______ ___________170
0.3______210.5_______197.03______182.6
0.35_____220.5_______206.72______199.5
0.4______224.39______208.34______212
0.45_____227.57______ ___________220.8
0.5______228.91______ ___________
Exhaust (stock):
0.05_____30.79_______
0.1______63.59_______62.9
0.15_____96.72_______
0.2______126.34______117.3
0.25_____135.04______
0.3______141.73______146.2
0.35_____144.41______149.6
0.4______147.08______151.3
0.45_____149.76______
0.5______151.6_______
Headgames stock intake vs stock intake with performance valvejob (stock valve)
Lift(in)_Stock__Valvejob
0.1______89_____97
0.2______130.4__166.9
0.25_____170____198.8
0.3______182.6__216.9
0.35_____199.5__223
0.4______212____228.7
0.45_____220.8__232
SuperRunner
A) Stock
B) Feb 2006 1st attempt at porting (gasket matched)
C) B + 30degree backgrind
D) June 2006 more porting same head (later said he made bowl too big)
E) D + cut valve guides
F) Jan 2009 (3 heads later ~= professional type job) stock valve, cut guides
Intake:
Lift(in)_A_______B_______C_______D_______E_______F
0.1______89.65___86.92___88.2____89.38___90______92.1
0.15_____ _______ _______ _______ _______ _______132.5
0.2______158.27__167.27__168.31__163.93__161_____171.3
0.25_____ _______ _______ _______ _______ _______207.6
0.3______197.03__213.17__214.86__216.14__216_____236.1
0.35_____206.72__225.25__228.22__228.47__229_____257.8
0.4______208.34__231.51__233.2___237.95__239_____270.2
0.45_____ _______ _______ _______ _______ _______280
0.5______ _______ _______ _______ _______251_____
I this this is fascinating, so I tried to zoom in to highlight the region where the different aspects of porting changed the flow
Exhaust:
0.1______62.9____70.29___71.02___72.43
0.2______117.3___128.37__130.38__126.23
0.3______146.2___163.16__164.73__159.38
0.35_____149.6___172.68__173.74__168.75
0.4______151.3___179.46__179.46__173.86
GiantTomato Intake (stock vs ported):
Lift(in)_Stock__Ported
0.05_____39.3___39.7
0.1______82.5___83.2
0.15_____129.7__125.5
0.2______163.3__163.3
0.25_____191.4__191.4
0.3______210.5__216.7
0.35_____220.2__235.4
0.4______224.4__243.5
0.45_____227.6__249.8
0.5______228.9__251.3
Exhaust (stock vs ported):
0.05_____30.8___31.3
0.1______63.6___65.3
0.15_____96.7___103.2
0.2______126.3__136.4
0.25_____135.0__162.3
0.3______141.7__178.2
0.35_____144.4__185.4
0.4______147.1__193.8
0.45_____149.8__201.0
0.5______151.6__203.8
ma71supraturbo
Redding, CA
www.geocities.com
2JZGTE
Stock Intake:
Lift(in)_ErinC_BXRsupra_poggie_M2racing_silvino_StuHagen
0.05_____ _____ ________50.1___45_______45______
0.1______ _____81_______100.5__92_______97______80
0.15_____ _____ ________148.8__136______138_____
0.2______ _____155______186.7__168______169_____154
0.25_____ _____ ________212.2__190______190_____
0.3______ _____199______231.8__205______210_____195
0.35_____ _____ ________241.9__217______227_____
0.4______238___207______246____225______228_____207
0.45_____ _____ ________ ______229______228_____
0.5______ _____215______ ______231______228_____215
Stock Exhaust:
0.05_____ _____ ________37_____38_______36______
0.1______ _____65_______76.3___82_______75______74
0.15_____ _____ ________105.3__106______109_____
0.2______ _____122______124.2__120______128_____120
0.25_____ _____ ________135.8__129______140_____
0.3______ _____145______141.7__136______146_____140
0.35_____ _____ ________147.5__137______150_____
0.4______154___151______148____138______154_____152
0.45_____ _____ ________ ______138______154_____
0.5______ _____152______ ______139______154_____154
Note: Silvino tested with manifolds on
Silvino Stock vs Supraformance Ported
Intake:
Lift(in)_Stock_Ported
0.05_____45____47
0.1______97____93
0.15_____138___137
0.2______169___174
0.25_____190___205
0.3______210___229
0.35_____227___243
0.4______228___248
0.45_____228___248
0.5______225___248
Exhaust:
0.05_____36____42
0.1______75____90
0.15_____109___119
0.2______128___140
0.25_____140___152
0.3______146___161
0.35_____150___165
0.4______154___166
0.45_____154___166
0.5______154___166
Stu Hagen Stock vs SHP stage 1 Ported
Intake:
0.1______80____97
0.2______154___174
0.3______195___230
0.4______207___260
0.5______215___265
Exhaust:
0.1______74____80
0.2______120___140
0.3______140___170
0.4______152___180
0.5______154___185
T78supra Stock vs Stock +1mm valves vs Ported +1mm valves (unknown pressure -- probably ~20")
Intake:
Lift(in)_Stock_+1mm_Ported+1mm
0.1______66___72___81
0.2______131__141__158
0.3______169__179__199
0.4______180__191__214
0.5______190__198__221
Exhaust:
0.1______60___65___79
0.2______115__123__147
0.3______138__145__163
0.4______142__152__165
0.5______144__158__166
suprwhp Ported, +1mm valves, cut guides
Intake:
.1 117.7
.2 202.7
.3 266.2
.4 296
.45 306.3
Exhaust:
.1 89.3
.2 165
.3 176.6
.4 184.1
.45 191.5
M2 Racing (stock vs M2racing CNC ported):
Sport&
ma71supraturbo;1347114 said:
Stock heads:
Ported:
Great graphs, but i am very confused by your 1j info. I have always read that the 1j flowed more on either the exhaust or intake. having them flow 10 percent less overall is something i have never heard. Who has flow tested their 1j heads?
ma71supraturbo
Redding, CA
www.geocities.com
As I posted -- the only data I've found is from Erin Carpenter. Here is his post on SF:
Erin Carpenter said:
It has been a very common rumor on here for a long time that the 1JZ head flows better than the 2JZ. This has lead to alot of people doing the 1.5JZ swap or atleast wanting to. Over the last few weeks I have been building a 1JZ, including porting the head, for a customer. I flowed the head on our SF-600 flow bench before and after I ported the head.
A stock 2JZ flows about 238in and 154ex at .400 lift. A stock 1JZ head flows 215in and 133ex at .400 lift. After I did a good street port job including reworking the chamber the 1JZ head flowed 230in and 152ex at .400. This should put to rest the idea that the 1JZ head is better than the 2JZ, because the fact of the matter is that it is not better.
Erin
http://www.supraforums.com/forum/showthread.php?t=339560
ma71supraturbo
Redding, CA
www.geocities.com
rwd;1348238 said:
the flow of 2jz stock head that Erin Carpenter flowed is not same as my friend 2jz stock head?
for intake port ,at .400, my friend had 215cfm and after port&polish he had 234cfm???
bizarre
That is part of the problem with comparing flow numbers. People have reported their 2JZs flowing anywhere from 215-250 stock just because of differences in flowbench calibrations (with 230 being the average). Since Erin Carpenter presumably flowed both heads on the same equipment -- then the percent differences (at that one lift) should be accurate. Still, the 1JZ data is woefully lacking, and I welcome any new information/numbers that people may have.
bobiseverywhere
bobb'n for money
Montreal
www.bobiseverywhere.com
i am not to sure how that keeps happening with the rumor about the 1J. the only thing the 1J head has over the 2J is air Velocity as i understand it. it may flow less but it flows the air at a higher velocity. That's what i have understood from tid bits here and there i don't know if anyone has data to back this up. Possibly this theory is based on the shape of the ports. not to sure anymore.
tissimo
Stock is boring :(
Melbourne, FL
If you look at the 1jz ports (intake) vs the 2jz, you'll see why the velocity is higher. The ports are smaller and with smaller ports you'll have higher velocity with similar flow (lower lifts). But of course with a smaller port and you run out of flow faster then the larger.
rwd
60
quebec
if i port&polish 1j head, is it possible to acheive the same results as 2j
i think 2j can flow about 300cfm with crazy job
Guyana00
Droppin that JZ in soon!
Apr 18, 2007
1,208
Brampton, ON
Anyone notice the difference in flow when it comes to intake and exhaust when comparing the 7m and 1j? 7m looks much better than the 1j for exhaust and the 1j looks better than the 7m for intake.
SupraClaou
846
Athens,Greece
Head job (port & polish) should be done only when you wanna push
big HP numbers...
Some guys stated that a ported head will start to 'pay off'
only after 700-800 whp...at least on a JZ engines :sarcasm:
Till then the stock head is more than ok :biglaugh:
RacerXJ220
Interdimensional
Abalama
We know we can make 700WHP+ on most of those heads stock flow. I wonder what the limit would be for the 1JZ exhaust port assumed max flow.
