Few quick questions on dissasembling the subframes.
I can not the the sway bar end links to come off the sway bar or where its attached to the subframe. The nut/bolt jsut keeps spinning and wont loosen up. Is there a trick to this or a certain way to do it.
Also the the little pins that are going through the end of some of the studs/bolts to stop the nuts from loosening up will not come out so i can take the nuts off to dissasemble. Again is there a certain way to do it.
