stuttering problem
forcefedsupra
aka, Turd Furguson
Jul 19, 2005
463
Jacksonville, FL
I changed my front seals and timing belt recently. It ran great for about ten minutes, then it started stuttering any time I touched the gas. It got worse and worse until it would do it all the time. I found out the timing gear jumped a tooth. I corrected that but it didn't help. After sitting for two weeks, it still does it but not all the time. I thought I bent my valves but it would run bad all the time if I did. Any ideas?
8,900
Since you found the timing was off, but then the symptoms stayed, did you look to see if the tensioner spring is ok?
Perhaps it is still off.
Burntz
Sold the Supra
Apr 20, 2007
582
Nebraska
check the tensioner, and make the sure the pulley itself cant be adjusted
btw, you cant and wont bend your valves?
MKIIINA
Destroyer of Turbos
Plano, TX
the 7m is a noninterference motor so you cant bend a valve unless something is very very wrong.
check the cps and the ground u have on the coils. if its a weak ground it could lead to a problem similiar to what you described
forcefedsupra
aka, Turd Furguson
Jul 19, 2005
463
Jacksonville, FL
I will check the cps. I don't have an afm, I have a MAFT. I have never had the ground on the coils and it has never done this in five years that I have owned it, but I will put one on. The spring on the tensioner seems fine.
