stupid question about R154!
kuroi_tuki
Richmond
Hi! I have a 1990 JDM RHD 1jz Turbo R.I am wondering if there is any way to see if the tranny has stock clutch without dropping the tranny? and would oem toyota clutch will hold about 330ft-lb torque?
here is my setup
1jz-gte w/ trust cone filter, trust 3" cat-back, 3" down-pipe, high-flow cat, blitz bov, and boost controller......
with this setup, and if I run 1.2bar (~17psi), does the oem clutch able to hold that power if I floor the gas sddenly?
Thanks for all ur help, I tried to search, but only thing I found is that the r154 can hold alot of power w/ stronger clutch, but how bout oem?? no one ever mention it???
Note: I don't race, I just drive a bit over speed limit, but sometimes I like to play w/ 350z, G35 for fun........
BlackMKIII
Hardcore Lurker
Jan 6, 2007
2,134
Norman, Oklahoma
www.facebook.com
The only way to see if a clutch is OE is to either A.) Have someone who's driven stock and modified clutches tell you or B.) pull the tranny.
Wlecome, BTW. :D
Edit: "The only stupid question is the one that is never asked"
Unless it's been answered 20 times already and you forgot to use the search function. LOL.
Rich
tunin' tha beast
Jun 2, 2007
319
the netherlands
Ehm, BlackMKIII, there are two inspection plates at the bottom of the bellhouse, and as most aftermarket clutches have these nice bright colours, like red and blue and stuff it's fairly easy to check if you have an oem clutch or not.
So, mr tuki, if it's grey, it most likely will be the oem clutch.
Oh and welcome.
edit: damn IJ, you beat me on a couple of seconds, lol!
kuroi_tuki
Richmond
thanks everyone, i will try to look at it on sat,
btw, does oem clutch able to hold ~330ft-lb torque??? i dun want it to slip after i replace oem clutch in it!!!!
Jayhall
WHIP THE PISS OUT OF THEM
May 7, 2005
1,167
Surrey BC
im fairly certian it will hold 330ft/lbs. I had my 7M at 320 and never had any issues with the stock clutch
p5150
ASE and FAA A&P Certified
Central Idaho
Yeah the stock clutch has single splines around the transmission input shaft but you probably wont be able to see it. I think the stock plate says AISIN on it somewhere....
kuroi_tuki
Richmond
i am trying to sell the car, n my plan is to fix the clutch and sell it for higher, or sell it as is............ i am savin up for jdm MKVI!!!! They are so sexy!!
Freshmaker
396
Oconomowoc, Wi
I didn't even know they had come out with a MKV yet :p
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
maybe it was the second "supra" concept car :) there has been what... 4 now?
