stupid cheap ebay gaskets
Suprapowaz!(2)
2,870
San Antonio, Tx.
Were the stock head bolts brand new, or did you reuse the old ones? It's not recommended to reuse the stock head bolts.
FWIW, I have a cheapie Evergreen headgasket I don't plan on using if you're interested. It should be ok for an n/a when torqued down to at least 72lbft. If you want to give it a go with the same HG let me know.
supra90turbo
shaeff is FTMFW!
32
MA, 01440
Tear into it again, clean the head and block, and install the Toyota HG.
Torque the factory headbolts to 75ft/lbs and drive it. Sucks, but you'll remember that cheap gaskets are cheap.
Kckazdude
1,239
Memphis, TN
By whose recomendation? These are not TTY bolts. They can be re-used as long as they are not stretched beyond spec or corroded from BHG.
Suprapowaz!(2)
2,870
San Antonio, Tx.
I thought stock toyota head bolts were TTY. They're not?
EDIT: I just looked it up on TSRM... they're not. They don't have the torque sequence of a TTY bolt. These are conventional bolts and can be reused. I was misinformed and have been passing along this info for a while. :: facepalm ::
supraduper
126
merrimack nh
ok well i'm about an hour and a half into the work and i'm just about to remove the head bolts... just wanted to get on here to get the removal sequence..
no fucking around this time
supraduper
126
merrimack nh
definitely 4-5 thats blown... all others look shitty too.. had to have been the torque...
definitely a bitch to get the head out of the engine bay by myself... i must have had a friend last time...
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
Damn, that's a bad blow for an NA.
Hopefully you can clean it up, install a Toyota HG and reassemble.
Good luck man! :)
supraduper;1512321 said:
i can imagine setting the cruise at that fast around here... the cops are pretty much nazis around here... overfunded nazis at that, were lucky to not get pulled over going 70 in a 55..
i dont know what the deal is.. but i will find out tomorrow what happened..
your right i should have gotten more than 5 k out of it... as the oem gaskets made it 50-100k before blowing... i am still gonna blame it on the gasket... we will surely see though... hopefully i get some pics up tomorrow
Well I don't know how the cops in Utah are, but it was after midnight in the middle of nowhere on a 75mph highway. At one point we went just shy of an hour without seeing a SINGLE other car. Just wanted to make sure you knew it wasn't in traffic or anything. Wildlife was my big concern.
^ you doubt wrong. a cheap hg can blow at anytime. you need the proper torque and a proper hg for the engine to last. buying a 50$ hg and expecting it to last is just wrong even for a stock style hg.
supraduper
126
merrimack nh
it was definitely a torque issue... it seemed like the bolts around that cylinder were loose when i went to remove them...
but i wouldnt be supprised if it was also made worse by a lean condition.. as the o2 sensor is known bad and i was running the car without it for a long time...
the car ran great without it... but lately i was tired of running through my gas so i plugged it back in.. and it was noticeably slower in closed loop but much better gas mileage...
ignition timing is advanced a little bit also, but i always run premium..
JDMMA70
2,550
Houston
Evergreen headgasket are complete and utter crap, i wouldnt trust those headgaskets EVER. Get OEM Toyota
black89t
boost'en down 101
Oct 27, 2007
951
humboldt, ca
my cheap felpro hg lasted me almost 2 years of hard driving until i leaned out from a boost spike and crushed a coolent jacket ring (i'm positive it would have lasted longer if this didn't happen).
not to say those hg are good. i have a couple eristic hg sitting around and they are extremely crappy quality.
but i say a ishno, felpro, or oem hg will be just fine. just depends how much you want to spend. that order is from least expensive to most.
gl.
