Struggling under acceleration
Duds
King Awesomo
Jun 24, 2005
97
Toronto, Ontario, Canada
Just rebuilt my 7m everything sounds good engine idles great but as soon as you give it gas it stumbles, almost dies, then comes back. Timing was set when I put it all together but going to recheck in the morning. It has some old gas in it, thinking it might be the problem but would like some other opinions before I start siphoning a full tank.
Edit: The car also takes about three tries to get it to start, regardless how long you try each of those three times.
rawmk3
170
IL
Check your MAF. Non metered air getting into the system will do that. If your turbo, check your intercooler and piping for leaks, and them make sure your mass air is plugged in, and if your NA, make sure all your pipes are free of leaks, and then check the mass air. That would be my best guess. It can idle unmetered, but once fuel is given it richens up to the point it dies. Basically flooding the car. On start up do u get a bad gas smell out of your exhaust?
Duds
King Awesomo
Jun 24, 2005
97
Did the timing made no difference, noticed my coilpack wasn't grounded but that also made no difference. Pulled codes 41 and 52, tps and knock sensor. Knock is probably from it starting as it barely starts but once it does it sounds smooth. All my pipes are tight and no cracks (most are new). No gas smell either
rawmk3
170
IL
I just looked at another thread that made me think of this, but there is a brown wire that comes off E2 and goes all the way to the AFM with connections to the CPS, and ECU temp switch. I would check that. I had an issue similar and when I looked, i had cracks in my wire loom, and exposed and broken wires. Fixed the wires up, and no more spitting and sputtering, and ran just fine. Might be something to look into. Maybe run a continuity test from the CPS to the ECU e2 pin.
You already know the answer...
rawmk3
170
IL
He pulled the codes, but that doesnt mean that is exactly what is wrong. It just means the ECU isnt reading that sensor correctly. Could be in the wiring easily. And checking the wires is alot cheaper than replacing a sensor. And then do a test on the sensor while your there too.
A bad or incorrectly installed and set TPS will give him EXACTLY the symptoms he's seeing. The ECU throws a trouble code for a reason and most of the time will tell you EXACTLY why the car is not running right...
rawmk3
170
IL
You said you did a rebuild on the motor, did you do anything to the TPS such as move it, remove it, or is it exactly the same as it was when you pulled the throttle body off the intake? Reason I say possibly wiring, is he did a rebuild on the motor. The wires are prolly 18+ years old, and probably dry rotted, and cracked. Moving the harness around when pulling the motor could have broke a wire easily. So putting a continuity test to the wires first would be a good idea, to make sure the lines are reading correctly, then looking at the TPS and where it is set at. Added resistance in the wire from being broken or oxidized could send false readings to the ECU
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
Hey lets all do what I just! Bought a brand new wiring harness for my '92, though I got the last one produced by Toyota, you can still find 87-90 I am sure. I paid $530.00
LOL
stabbinkabbin
Spring TX
Poodles ftw, if your tps is the slightest off it messes up. =( I have been trying to tune mine forever now it seems. Using shims and a continuity tester to measure resistance between throttle points.
Duds
King Awesomo
Jun 24, 2005
97
Mod list on this car:
Stock lol, unless you count mhg and arp's to be mods, I've had this car sitting up where I work for the past 2 years just started rebuilding it this summer.
zachm611
Beauty In Disguise
Apr 15, 2006
544
new mexico
fixing the tps will help with idle and acceleration. and fixing the knock sensors most likely the wiring will help with acceleration as well. i had code 52 and as soon as i got to 3 or 4k rpm... instant limp mode. get your codes fixed and let us know how things are going.
why would you be adding shims to the tps? all you do is move the sensor into the proper resistance range and tightin the 2 screws. if not as specified replace.
