STRANGE LIGHTS
suprabad
Coitus Non Circum
Jul 12, 2005
1,796
]Just like the title suggests I have some headlight anomalies.
Here's the problem.
When I turn my headlights on, I get all appropriate exterior lights, except my low-beam headlights. When I switch to hi-beams they work fine.
I checked fuses and relays...all OK.
As a last resort I replaced my entire combination switch (lights turns, wipers, everything) and Bang it all worked great, problem solved...I thought.
Last night (it's been a couple of weeks since I changed out the combination switch) I get in my supra and same thing. Every thing works but the low beams.
Also, when switched to low beam the hi beam indicator lights up.
Has anybody had a similar experience? Any Ideas?
Also, what does integration relay #2 do?
Shytheed Dumas
For Sale
Mar 6, 2006
967
Louisville, KY
Mine does kind of the opposite; low beams work fine, but everything goes out when I flip my high beams on. I brought this topic up a while ago and somebody suggested that the contacts are probably dirty, and that pulling the steering wheel and a good cleaning would fix it. One of these days I will get to it.
suprabad
Coitus Non Circum
Jul 12, 2005
1,796
Done that.
Adampecushum said:
have you confirmed that both low beams haven't just burned out?
Done that... As I said I've already replaced the combination switch.
bluedragon17
87 NA-T baby!!!
Sep 14, 2006
382
Vacaville, CA
happened to my old DD take out the combination switch and check all the contact points one of mine came unsoldered and thats why my low beams wouldnt work but the highs would
