]Just like the title suggests I have some headlight anomalies.
Here's the problem.
When I turn my headlights on, I get all appropriate exterior lights, except my low-beam headlights. When I switch to hi-beams they work fine.
I checked fuses and relays...all OK.
As a last resort I replaced my entire combination switch (lights turns, wipers, everything) and Bang it all worked great, problem solved...I thought.
Last night (it's been a couple of weeks since I changed out the combination switch) I get in my supra and same thing. Every thing works but the low beams.
Also, when switched to low beam the hi beam indicator lights up.
Has anybody had a similar experience? Any Ideas?
Also, what does integration relay #2 do?
Here's the problem.
