Strange click/clunk noise
Kevin
7mgte -> 7mgte swap done.
Apr 20, 2009
865
Windsor Ontario Canada
Hi this will be hard to describe.. but i'll try anyway..
there is a click/.clunk noise.. everytime i start to brake oorrr turn the wheel more than half a turn (when i am both driving and stopped). sometimes it happens.. sometimes it doesnt.. its coming from the front passanger.
any ideas what it may be? i had the wheel off. and everything looks ok..
Kevin
Apr 20, 2009
865
nope. its just clicks ONCE when i brake.. and then any more letting go and pressing the brake again does nothing.. untill i drive off and then brake again then it clicks lol hopefully that made sense.
but like i said.. it also makes the exact same noise when i turn too.. so i dont think its the rotor
7Matt-GE
407
Becker, Minnesota
hmmm rack and pinion? my clicks like a mofo..like...not just a mofo...a freakin super mofo
Edit: just to clairfy sometimes it only clicks once too...just throwin ideas out there! :)
Kevin
Apr 20, 2009
865
also its not the usual clicking like when i hit bumps, cracks etc.. its like a loud click/clunk.. LOl i wish i had a camera or something to record this noise.
supraduper
126
merrimack nh
if its only related to the braking.. then check your brake pad shims... does it click in both directions?
when is clicks when u turn the wheel when not moving, is your foot on the brake also?
Kevin
Apr 20, 2009
865
mecevans;1530709 said:
no offense but didnt you hit a curb a little while back?
yes i did lol. but ya.. trying to figure out exactly what damage that caused.
---------- Post added at 01:41 AM ---------- Previous post was at 01:40 AM ----------
btw sorry for the late reply. didnt even know there were more responses :S
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
78
Atlanta
I have that problem as well. When I start from a stop, I hear a loud- almost a tap sound, like someone lightly smacked a hammer against a thick piece of metal. I haven't investigated it much yet, but i imagine it has something to do with the brake pads/ shims moving slightly.
Kevin
Apr 20, 2009
865
for me i know that hitting the curb was definately the cause because the noise wasnt there before...
but idk what exactly to investigate. i was hoping someone that had the same problem before would chime in :)
SupaMan
Want The Boooooossttttttt
Oct 12, 2006
1,101
Cape Coral,Florida
Jack that side up, Set the car on stands, Leave the jack under it, Start pulling forward and backward in a parallel line with the cars movement and see if anything makes noise, Try rotating the rotors back and forth the same.
Kevin
Apr 20, 2009
865
leave the jack where?
