Stock o2 with welded bung?
mk3-4-me
669
Milwaukee, WI
Ok so I have a 3 in v-band DP with 2 welded o2 bungs... They are both screw in types though, and the stock o2 has those 2 bolt holes... Right now I just have the o2 in the bung with a wire through the bolt holes and wrapped around the DP... Lol
That's all I can do right now! I obviously have an exhaust leak there cause it's not tight.
I was wondering what you guys suggest or what you have done in similar situations.
ThankS
mk3-4-me
669
Milwaukee, WI
Cool! I ddnt even thunk of anythin like that! Lol
Where would you look for one of those? Is it car specific? Like I think my civic o2 sensor is a 3 wire and its a screw in...
Thanks! And does it have to be right after the turbo? Or could it be down by the tranny?
And Where is the best place for a wideband? Cause I have 2 spots.
1 close to the stock location right after the turbo and another down by the tranny...
I'm trying to decide where I should put each one.
4
You can pick up a 3 wire O2 from any parts store. You'll have to wire it in though.
Wideband should be farther away as it's more expensive and will last longer if it's farther away.
mk3-4-me
669
Milwaukee, WI
Ok thanks guys. I'll check out how much a sensor is.
I was gunna put the wideband Down lower I just wanted to ask.
Where my bung is down there, the WB sensor sits in the tranny window thing on the side(dnt have the covers). I think I'm gunna have to wait to get one treeless in a better place because the sensor end sits just behind the Pressure plate! I deff don't want it to get hit and broken. Nothing touches when it's in, but idk what will happen when I start it up. I'm scared when the PP starts to spin something may hit it. :( I'm not about to risk my WB sensor!
