stock injector limits?
joeyd23
GTE4ME
Sep 18, 2007
72
waldorf maryland
i plan on haveing my car tuned sometime this spring and i was wondering what efect the stock 440's would have. i do have a FPR, apex'i neo and a lex afm. thanks for your time
NewWestSupras
SoupLvr
Mar 1, 2006
611
White Rock
If you are going to all the trouble of those mods, then upgrade the fuel pump and the injectors as well. The Lex and 550's are done a lot, as they are both approx. 25% bigger so it balances out sorta ghetto. Don't forget to drill out your j-tube! gl.
joeyd23
GTE4ME
Sep 18, 2007
72
waldorf maryland
yea i have a fuel pump curently on the way. j tube to what?
92nsx
2,957
Clearwater, MN
Better yet just remove the J tube and install a chevy block off plate.
If your lost what the J tube is look here.
http://www.cygnusx1.net/Supra/Library/EPC/291420/catalog.aspx?F=2211&P=2
this is the only pic I could find, it is # 23809 in the lower left corner
shaeff
Kurt is FTMFW x2!!!!
11
Around
I just chiseled my j-tube off the plate, ground it down, paint, done. :) Looks just like new. ;)
joeyd23
GTE4ME
Sep 18, 2007
72
waldorf maryland
maybe ill try that. so what is the purpose of the j tube and what are the benifits of bypassing/blocking it off?
edit: nevermind i searched and found the answer(wow imagine that)
joeyd23
GTE4ME
Sep 18, 2007
72
waldorf maryland
so back to the injectors does anybody have any input as to what my limits are as far as boost whilw on stock injectors? (FPR, lexAFM, walbro255, apex'i neo, inovative wideband)
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
im sure if you search... u can find what some people have done with stock injectors here on the forum. but if i were you, i would send the injectors out to get cleaned and flowtested. if ur planning on raising the boost, i wouldnt trust injectors that are 20+ years old. but if your going to go that far, you might as well just get new injectors
-pete
GC89
1J-THIS
Jun 13, 2007
938
Spokane, WA
The stock injectors deserve more credit than most people give them. I would deffinately get them cleaned and flowed though. They will be fine under 14 or so psi, most just feel safer replacing them or just go with the general concensus that you have too.
Hey duane ran them on 20 psi and that worked out pretty well:sarcasm:
