Stock 1j Flange For Upgraded Turbo's
ryangaudoin
Toronto
Hey everyone i just want to know what kind of flange is the stock ct12a's on??
I heard it was either a t3 or a v-band flange??
Thanks
Ryan
ryangaudoin
Toronto
aright well i know that like the hks t3g turbo's are the full replacement for the stock 1j twins, but thats hard to come by
so are you guys saying that the stock 1j manifold flange's is only for the flange for the twins, cause i know if i upgrade the twins i will have to do the custom work for the turbos to the intercooler, the air intake, and the y-pipe??
935motorsports
San Diego, CA
This is the flange that bolts to the stock 1jz manifold. Then you can adapt a couple of small twins from there, or join them together to build a cheap single manifold adapter.
ryangaudoin
Toronto
im thinking of 2 garretts, so then this 3bolt flange will fit directly on the stock 1j manifold
jizake1jz
FTMFW
Feb 18, 2007
146
Lake Zurich, IL
oh i see what you're saying, you want to upgrade twins but keep the stock manifold and use an adapter. why not just use a custom twin manifold. i'll make you one if you want :naughty:
ryangaudoin
Toronto
lol i would like that, but i think i might want to stay with the stock manifold and use upgraded twins plus i got a 180sx that im building for 500+whp for track,time attack, drag, show, everything.
im just waiting till i get a 92 mk3 with black interior, with low km's and my mk4 big power:naughty:
ryangaudoin
Toronto
btw does anyone know what the stock ct12a's each are rated at hp wise???
Im planning on running maybe garret's gt15 turbo's but as the site says the turbos are meant for lower displacement engines
http://www.turbobygarrett.com/turbobygarrett/catelog/Turbochargers/GT15/GT1544_454083_2.htm
check it out and if anyone would let me know if i could run these on my 1j
and does anyone know any hks 3bolt flanged turbos cause on the hks site it doesn't show any, im really looking into around 400rwhp
thanks
935motorsports
San Diego, CA
The thing is by the time you make adapters, you will have already paid for a twin turbo tubular manifold for 1jz.
I had mocked up some adapters to run twin wrx turbos. But all of the time I spent on it, I should have just gotten a twin manifold.
ryangaudoin
Toronto
ehh thanks for the info anyway i got more info from different ppl and i guess i might as well go a custom twin manifold as you said 935motorsports, and run some twins with internal wastegates
thanks for everyones help
Ryan
