ive searched and read and searched more along with read some more. when using the lex afm and a afpr with 550 injectors, is the ideal setting goin to be to max out the adjustment screw (out) then add fuel pressure (or take it away) to get the idle down? then add pressure to keep wot in check?
isnt the whole point to get more air through with out the pcm seeing it (raising fuel cut) and add fuel to keep the added air that isnt metered in check? hence the idea that you max out the afm and raise fp accordingly?
also at this point with out a piggy back to add more fuel through injector pulse width, you either tune for idle, or wot (car has sp61gt on a 7mgte with all fuel upgrades minus walboro hitting fuel cut at 14psi) correct?
