Im trying to figure out what is causing this. It bump starts fine, but occasionally the starter hasnt been turning over.
I put the key to ON, fuel pump turns on
Turn the key to start, lights dim, voltage dips (3-4V dip), starter does not crank
Rarely I will be able to put it back to Off, then try again, the starter will turn over and the engine will start
The battery is obviously not dead, but does this mean it simply doesn't have enough power anymore to turn the starter? Before this happened last night I had just driven through the canyons, it was not a short trip, the battery should have been charged plenty. Sat off for just under 2 hours.
Is this a loose connection to the starter?
A bad starter/starter going bad?
