Got the starter click issue a bit ago (after a rebuild). Swapped starters w/a known good one, replaced the 0 gauge ground at the battery (in the hatch), replaced battery & terminals, replaced power wire to the starter (from a distribution block in the engine bay. Still getting the click...
Starter relay seems okay, so what else can I check? Would the starter solenoid wire cause an issue with the starter not having enuff cranking power (measured 11.74 volts, the last time I checked when cranking)? Just tired of replacing things and could use a bit of guidance... thanx for your help.
Before changing the starter, I was able to crank when the car was in gear sometimes. After I swapped starters, cranked okay (once or twice), but then click started happening again.
