stacked headgaskets
quake
toyota tech
Apr 13, 2005
619
r.i.
so there is a local guy here with stacked gaskets to get the compression he wanted. he has a felpro on the block a steel shim and then another felpro hes been running this way for a year at 16psi on a 57trim pump fuel just bumped into him again and thought it was pretty funny :biglaugh:
quake
toyota tech
Apr 13, 2005
619
r.i.
IJ. said:
Way back we used to use decomp plates with 2 gaskets.....
A 7M is the last motor I'd try it on though ;)
thought you would find it funny though poor prep work people cant even get one to seal this guy has 2
LOL probably find 2 would seal quite well as there's so much gasket material it can flex to fill any gaps ;)
(that and not enough compression to ever detonate)
It has to do ugly things to the squish and efficiency of the motor at cruise though.
