SSQV supra Specific recirculated kit?
gotsomegetsome
Age Quod Agis
Mar 31, 2008
210
san jose
thanks for the reply but thats not it
you can find that anywhere, but I just wanted to see if there was an actual specific kit.
what do people use anyways as an option to that
airhead04
1,489
Lima, Ohio, United States
Im not sure what your asking?? You want a bov thats specifically made for the supra?? Or the adapter to recirculate the air?
A bov will either be recirculated or not. A recirculated one forms a looped system, and non recirculated "blows off" to the atmosphere.
Hope that helps.
There is no other option. You get that and some hose and take one of the blocked off ports on the accordion hose and run a hose from the bov to there.
All the other kits come with is another hose + that piece.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
No, what he means is a kit built for the Supra - so, a pipe with the HKS mount already attached, hoses to connect to the stock locations, the BOV itself as well as the recirc fitting.
As far as I know, this has never been assembled by one vendor. I suspect simply because it's so easy to put together yourself.
gotsomegetsome
Age Quod Agis
Mar 31, 2008
210
san jose
Thank you GrimJack. That is exactly what I meant. I'm looking for options, whether it be stock or completely modified. I had seen a handful of its that only gave you the fitting for the ssqv exhaust port and a bent tube, but they did not look very specific at all even tho they stated "for blah blah make model etc".
I guess im gone be making myself some custom pipes!!
ae86ma70
119
Atlanta
I understand the question, and the answer is "no". You can use a section of hose to recirculate the BOV, but the angles involved make it nearly impossible to keep from kinking the hose (without it being 2' long). I have an HKS BOV and the recirc adapter. I previously used an HKS intake pipe adapter designed to replace a piece of the stock IC piping. Currently, I run 3" IC piping, but ran into the same problem. I suggest trying some PVC pipe and elbows to make the tight bend from the BOV to the port on the accordion hose underneath. You might have to use a short section of PVC hose to make the length just right.
Jason
