sputtering issues
ihiryu
209
TX
Alright guys currently I'm 2jzget w/ 7m electronics. I have an aeromotive fpr, lex afm, rc550 hi-imp, dave h turbo kit, arp head studs, 2mm head gasket and zeitronix zt-2 wb02.
I just installed the rc550's and I bypassed the resistor box, car runs ok. I turn the fpr down to 34 psi and she barely wants to idle (with vacuum), I turn her up to 60 psi, car runs great.
Check my wb02 at idle, and it says 21:1. WTF? I see a lil smoke coming from the DP so I figure it's just a leak cause the wb to go crazy.
no codes at all, I was having an issue with 51 and 41, but that's taken care of now.
As I'm driving (fpr at 60) car runs ok, but smokes. I try to get into boost and the car falls down flat on her face. I can't tell you the RPM's cause the gauge doesn't work. I'm seeing roughly 11 psi. Sometimes lower, sometimes 11.5.
I turn the fpr back down to 34 w vacuum, same thing. The wb says anywhere from 11-13. But for a split second I saw it jump to 17/18 under boost. Now I'm only seeing 9 psi (i'm assuming the rev's are stopping earlier)
You guys have any ideas? I'm at ends wit, and I really dont want to search anymore cause my head hurts and I'm super frustrated.
Thanks guys, please guys if you have any ideas at all, I'm willing to give it a shot. I really don't know anymore.
wiseco7mgt
dirty mechanic
Aug 12, 2007
811
queensland
The first thing you should do is not boost at all until this is sorted, accidently running lean is a lesson i hard learned and wont do again.
What was your compression ratio after the 2mm h/gasket went in?What was your compression readings across the cylinders?What is your fuel pump?what is your timing?Are you running the car and looking for wideband values useing only a dump pipe?
Sorry for the questions im very interested though....
ihiryu
209
TX
it's hard to explain, it almost feels like I've got too much fuel, it pops and backfires.
Wiseco. Yeah but I need to run boost to figure out what's wrong...My fuel pump is a walboro unit. Timing should be stock @ 10 degrees. I have a full 3 in exhaust no cat. WB02 is in the downpipe.
I thought the lex afm/550's are a plug and play type deal. Or should I go ahead and get a safc? I don't want to really spend money without knowing that's exactly wrong.
ihiryu
209
TX
update! I got the safc in today, so I had some work cut up for. I installed the safc, took the plugs out, cleaned them up and gapped them. Currently I'm running the stock 2jzgtte spark plugs gapped down to 28.
I have the FPR set at a nice 45 psi with vacuum. I did some playing with the safc and it seems like my issue went away. What's scaring is me, is that I had to add fuel via safc. I still haven't got a 100% base tune yet, but I'm doing slowly.
It seems to still run rich though. As I drive it (changing both the safc and fpr) I can't seem to get it just right.
My wb02 around the 5500-6000 goes to 9. And then she'll sputter and stop.
My also getting code 34 still. I wasn't getting it before, but that kinda makes sense because It has to do the with the maf too. Considering that I put a SAFC on which alters signal from the maf. The safc tells the ecu that it's seeing too much air, so the ecu adds fuel. Does that sound right to anyone?
