Im trying to diagnose my spongy brakes. Please read the facts before blurting out a recommendation.
1. 14" w/6pot Precision Calipers
2. 3 different mechanics have swapped 3 different Master cylinders
3. The pedal gets nice and stiff with engine off when pumped
4. When the engine starts the pedal get spongy
5. The car stops, I can lock up the brakes but the pedal never stiffens.
6. I gone through about 2 gallons of brake fluid, even tried pounding the calipers and ABS unit with mallet while bleeding.
7. The idle drops if i pump the brakes while engine is idling
8. There are no fluid leaks anywhere.
I undertstand a leak in the brake booster will cause the pedal to be stiff with less braking force.
Even with a stock master cylinder, there should be more pedal travel with the BBK but it should still be firm at some point right?
What else can be the problem?
