speedo calibration thread
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
Jeff Lange posted some information some time ago about his experience with calibrating a speedometer. Ive looked for the last 30 minutes and still cant find it. Does anyone happen to have a quick link to it, or know what the name of the thread was?
Sorry for such a stupi request, but I got my gauges apart right now and cant find the silly post....lol
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
Well, I'd only see his thread on it on that other forum.
Keep in mind that it does nothing for the odometer's readings.
DyslexicSquirrel
Busy Member
Mar 9, 2006
239
San Marcos, TX
I was getting help from Jeff with my gauges on SupraForums as well... but then they banned me because I asked for help changing my SN, now they wont respond to my emails... I need to talk to Jeff about that. Argh!
bigaaron
4,692
Pomona, CA
www.driftmotion.com
I don't understand the reasoning behind him saying the odometer is calibrated for any trans and differential gear ratio. That is impossible. Reguardless of what you started with, if you change the rear end to a different geat ratio the odometer will be off by the same percentage of gear change. So if you had a 3.70 diff stock, and you changed to a 4.30, the spedo AND odometer will be off by 14%. So at 80mph for 1 mile on the spedo/odo, the actual speed would have been 68.8mph and you would only traveled .86 miles.
CRE
Oct 24, 2005
3,485
Denver, CO
bigaaron said:
I don't understand the reasoning behind him saying the odometer is calibrated for any trans and differential gear ratio....
I guess he wasn't clear enough on that... The speedo adjustment adjusts the baseline for the spring which pulls on the clutch assembly (the one in the speedo) which drives the needle... if the speedo wasn't built this way it wouldn't return to 0MPH. The Speedo and the odometer are however both expecting a set number of rotations from the speedo cable, it's the cable's drive gear which makes the difference here.
Perhaps that'll make more sense... that or I've REALLY confused someone.
bigaaron
4,692
Pomona, CA
www.driftmotion.com
I see what you mean, but unless the spedo is out of adjustment, it couldn't be wrong and the odometer be right.
Basically any gear change, tranny swap, or change in tire diameter can effect the spedo and odometer readings.
Jeff Lange
Administrator
4,927
Sunnyvale, CA
jefflange.ca
Any time you change gearing in the car, tire size, tranny, rear end, etc, the speedometer and odometer will be moved out of spec by the same amount. That is true.
However, over time the spring can weaken, causing your speedometer to read a higher number than you are actually going, while the odometer will still read the correct amount, that is because the odometer is directly geared to the speedometer cable, so any time the speedometer cable moves 1026 revs, the odometer has moved 1 mile, that's just the way it is and there's nothing that can change it. So, what happens when your odometer reads correctly, but your speedometer does not? You need to recalibrate the speedometer to read correctly.
That's where the calibration of the speedometer comes in. You can adjust it both higher and lower, and that calibration adjusment can move actually pretty easily. People who get speedometers and clusters shipped, shipping could easily move that adjusment slider.
The whole odometer/speedometer issue really is that you need to make sure the odometer is reading correctly before making adjustments to the speedometer, because if the odometer isn't reading correctly, you have a gearing problem that should be fixed before anything else. Once you have the odometer reading correctly, speedometer calibration can be done if your speedometer still is not reading correctly.
I hope that explained things a bit better, haha.
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
Thats a wonderful explanation, and I found the diagram on the other forum to explain which way to move the adjustment. My speedometer was reading about 5MPH fast even at low speeds and not much more at high speeds, but I adjusted the speedomter down a little....now all I need is one of those local radar thingys the cops put out to tell you youre speeding. I hope I dont have to take apart the gauges...AGAIN!
bigaaron
4,692
Pomona, CA
www.driftmotion.com
Ya, that explains it much better!
mkIIIman089
Ohio
Does anyone know how much correction is built into this adjustment? Obviously since each car is a tiny bit different to begin with it won't be the same, so how about an "over the entire range" kind of thing?
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
I hope this doesnt step on anyones toes, but I copied over the link of the picture jeff drew that helped me figure out how to adjust the speedo. this is it here:
dasz33
20
Denver CO
Sorry to dig this up but I have my cluster out of the car and need to adjust my speedo. Its reading about 4-5 mph high.
My question is, do I need to completly remove everything from the back of the cluster? The green circuit board plastic, and all of that? Or is there an easier way?
DaSuprawolf
Im SICK of N/A
Dec 29, 2005
456
ChicagoLand
so if i move towards the + side, it will make my speedo read higher? correct?
and vice-versa.
