Spec stage 5!?!?!
rakkasan
Currahee!!
Fort Campbell, KY
kwnate said:
I have a feramic disc with an aluminum flywheel(fidanza), as far as I know the friction surface of the flywheel is steel.
I pretty sure you are correct. I'm looking at mine & it sure looks like steel to me.
suprahooked
Built 7M
Jun 20, 2006
1,160
pa
I got a stage 5 Act clutch for sale Brand new for sale in Parts Clutch disc,presser plate,throwout bearing ,polit shaft bearing,alinment tool,$575 shipped ( Edit ) (Downsizing my build) Pm me
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
bringing this thread back how did yur setup work out??? i think my spec 3 is starting to go and im looking into the spec 3+ or RPS......Justin727 how did yur setup go???
Justin727
T-virus infected
well i havent heard anything about those 2 being tried yet.
But i did infact settle for the RPS and HPF disc. Like X-man has. Havent been able to drive her yet but if sean says its good then i have no doubts it'll be fine for me!
My engine is still on the stand
GotTurbos?
2J = Here; Swap = Near
Apr 24, 2006
951
Dallas, TX
im going to bump this off,
im stuck between the spec 3+ and the RPS stage 3, there are lots of high hp people in here so its great!
I need to know if I should spend the $$ to get the hpf kit, or if ill the stock stuff from spec and rps will be fine.
also on the flywheel subject, the fidanza is, or isnt fine? if it has a steel friction surface, it should be fine no?
thanks in advance,
Jon
