Spark Plugs
You ask the question after you order them?!?! Kinda backwards isn't it?
Those look a lot like the iridium design...if the performance is the same, they should work well. Check the gaps ;)
JtWo
Sniper
Apr 10, 2005
159
Bay Area
Nevermind I bought champion coppers instead because i heard platinums suck for 7ms. uhh...how much should I gap them?
mkIIIman089
Ohio
Champions are barely good enough for lawn mowers, and personally I wouldn't have run with coppers either. Hey, at least you'll be able to swap em out pretty soon when they wear out. ;)
Check the TSRM for the gap spec; and what do you mean with or without gasket?
drjonez
the motor city
www.4cefed.com
yeah, champion plugs have killed more than a few engines that i know of....
wouldn't run copper? might want to read:
http://www.mkiiitech.com/forums/viewtopic.php?t=36
SupraDupra500
195
Terre Haute, Indiana
i dont run anything but copper in my car.. i had iridiums, but it didnt make any noticeable difference. so after a while, i went back to copper. never any probles.. and champion plugs suck.. autolite are okay, but ngk work great bcpr7es FTW
7MGTEsup
Formerly 'Down but not out'
Jun 14, 2005
614
England
Sort the codes out, 52 and 51 will be killing the cars performance.
I had platinum plugs in my car for less than 1000 miles before the ceramic craked on 3 of them and gave me a missfire. Put in NGK BCPR6ES coppers (all 6 came to less than the price of 1 platinum) did 10,000 miles on them still looked like new when I changed them. Having to use platinum plugs is a myth, the guy in the shop told me that the copper plugs wouldn't last 300 miles, so I just laughed and said I'll take my chances.
bowsercake
828
Irvine, Ca
I'm running the autolite 3923, my old plugs were bad and so obviously these ones worked better. No problems yet but I only have a few thousand miles on them.
Imagination6788
30
Atlanta, GA
Is it bad if I haven't changed my spark plugs in about 60K miles and 10 years? My supra has a sticker in japanese and english saying to only use platinum tipped spark plugs.
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
Change them. You can just get copper plugs. NGK V-power are nice and cheap. I put some NGK-6097 heat range 7 in my car. I was going to buy Iridiums but then I learned that cheap plugs would work just as well and would possibly last longer.
jailbird25
53
Neugersdorf, Germany
Copper plugs in a 7MGTE????
ohhhhhhhhhhh nooo..............the V-Line NGK plugs are verry good for normal engines...are not for a turbo engine with high mods and pressure.
my Supra is running with NGK Iridium plugs.
NGK Laser platinium are good ( BCPR6EP-N-8)
1988SupraDreams
509
San Jose, CA
NGK Iridium IX Plugs in mine. Might be good for you JtWo if you're not a genius at gapping; they come pre-gapped.
And btw man, do yourself a huge favor and save up the cash and buy yourself a NEW EFI harness. Your car in perticular needs it.
bosco659
Toyota nut
Oct 11, 2005
Canada
The Autolite plugs are a bit shorter than the stock plugs. I have heard of issues of the spark plug wire boots popping off of the plugs causing issues. Any truth to this??
