spark plugs for 7mgte?
Supra5MGTE
421
Tampa, FL
I guess OEM is NGK platinum? What are you guys doing as far as heat ranges? Should I go 1 colder than stock? B/c I went 1 colder than stock on my 4runner and it runs a lot better. Plugs look better. So i'm debating just running some NGK V grooves 1 colder than OEM in this '90 T we're getting tonight.
shaeff
Kurt is FTMFW x2!!!!
11
Around
autolite 3923's gapped to .30
call it a day, enjoy great plugs, change them when you change your oil.
-shaeff
mkIIIman089
Ohio
NGK Iridium 1 range colder. NGK says 1 range colder for every 75-100 HP more you have over stock, use that to judge the heat range.
I'd reccomend against platinum unless the car is bone stock.
catch2nd
80's toyota lover
Oldest fair in CT
NGK coppers... 1.50 a plug at advanced auto
and like shaeff said... change them often, copper is the best electrode type for turbo applications, however they wear out quickly
Supra5MGTE
421
Tampa, FL
I notice the N/A 7M takes a 5 heat range plug. while the Turbo 7M calls for a 6 heat range; 1 colder. Since that's the case, I'll just run the NGK Vgrooves or stnd plugs the book calls for. see what happens. thanks.
shaeff
11
Around
whopwood said:
autolite 3923's are $1.50 for TWO at walmart. do the math, it's an extra $4.50 on top of an oil change. i'll spend an extra $4.50 to ensure my car is performing up to par. and, it's not like they're difficult to change, either... it takes 5 minutes...
i change my plugs every time i change my oil. cheap insurance.
-shaeff
