Spark plug torque spec?
Mk3runner
2,033
Nor Cal
huh?? you guys actually tq to spec... never in my life have I done that. always the rule of thumb method you know. never fails.
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
With spark plugs yeah. Anything on the head of this car, you beter tq correctly except the head bolts/studs. Always 75+ with those, factory, or the preferred ARPs.
SySt
Burnsville, Minnesota
Actually, if I remember right the torque spec on the spark plugs is about 23 lb/ft. I am a mechanic by profession. Neither me nor anyone else uses torque specs unless it regards engine internals or manifolds. Everything is as stated earlier "rule of thumb". Basically, experience.
SySt
mattjk said:
http://www.ngk.de/Tightening_torques_for_spark_p.652.0.html
I'd rather listen to an NGK engineer than you douchebags.
Douchebags? I beleive you are referring to those who have mentioned you do not have to tighten spark plugs to a precise manufacturer's torque specification. Torque specifications are there for a reason however are inherently inaccurate. Actual clamping force of a fastener is not measured in torque. On top of that, the best mechanics I know in the business as I said do not torque bolts to spec unless it is more critical such as engine internals. If you want more, I just left a job where I worked with a mechanic that did assembly work for Lull at his previous job. Even on the assembly line on "critical" bolts are torqued to spec.
pb92supraturbo
FTG & the IRL!
Aug 20, 2005
172
Garage, under Supra
Good lord . . . relax people. I can't believe people get slammed for trying to do a job right. All it takes is for you to experience one stripped spark plug hole (or any fastener for that matter) and you'd torque the plugs when installing. Personally, If I have torque specs for any given fastener I'm working on, I'll pull out my torque wrench and do the job right (like its so difficult to do and time consuming - can you feel the sarcasm??). Nothing like being torqued with a 'Dead on balls accurate' Snap On torque wrench ... 'Click' Ahhhh!
