spark plug for 1jz
OneJoeZee
Retired Post Whore
aboard the Argama
inline6
Whistle>Whine
Sep 22, 2005
208
SoCal
OneJoeZee said:
don't gap them?:icon_conf
the gap on the ngks is usually too high for my liking out of the box. I bring it down to .28-.30. Never broke anything...
mattjk said:
Always gap your plugs. If the electrode would break off during gapping, it sure won't last inside the engine
Thats probably because you guys are running the standard plugs like the 3330's or 6097's. Generally, you do not gap the plugs he linked to because of the brittle metals that they are made out of (Iridium and Platinum types)
On topic, I would just go with 6097's or the 3330's and keep up on your plug changes. They work fine and run about $2 each. Or you can get the stock plugs and pay $14 per plug. I believe that number is 3452 IIRC.
mattjk
Permanent Ban
May 18, 2006
1,973
Huntington Beach
What are you talking about? You don't bend the center electrode, you bend the ground electrode. BTW, an iridium or platinum ground electrode is NOT entirely made out of precious metal, usually there is a small tab of iridium or platinium fused onto the end.
BKR6EIX, the one he linked has an iridium center electrode, and a regular steel GROUND ELECTRODE.
It EVEN SAYS on the NKG website:
Should I gap my Iridium Plugs?
The manufacturers say NO.
This is because most people do not know how to properly gap a spark plug, and the center electrodes on the ultra-fine iridium can easily snap if mishandled. There is no warranty for snapped center electrodes. The manufacturers say an iridium spark plug will run so much better than a traditional plug, even if it is not gapped for that motor, that they would prefer you just leave it rather than risk snapping the center electrode.
Personally, we at sparkplugs.com, gap our iridium plugs for our own vehicles (we’re rebels). If you insist on gapping your iridium plug, please refer to Proper Gapping for instruction.
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
I was just saying that it is very easy to break the electrode. If you have a steady hand the the right gapper, go for it. I'm just kinda careless sometimes. Sorry for the confusion.
Erkenz
125
Michigan
Has anyone ever used the Champion DaimondFire plugs in their 1jz? I think you can use the same plug as for the mr2 turbo.
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
with the ngk irridiums can i boost my 1j bcuz it runs hotter than the ngk 6097s? i've been told that they don't last long and boosting makes them detanate
89toy
77
10,000 lakes
u would always want to run colder if u plan on raising the boosts. Hot is not always better. I also heard that irridium sucks for 1jand2j but than again i could be wrong so someone correct me.
bobiseverywhere
bobb'n for money
Montreal
www.bobiseverywhere.com
I took the Iridiums that i had for my 7M-GTE and put them in Since they were still brand new.
Mattjk Recommendeds Gapping at .28
I am not sure about the iridiums. Allot of people say they do not like them. I'll be updating my build thread once i have some experience with them in my engine.
I think stock you are supposed to use Platinum plugs like on the 7M-GTE
Just make sure you stay away from --->Bosch<--- Plugs
I believe the Stock 1J Plugs are the same as the MR2 and 2JZ plugs
RacerXJ220
Interdimensional
Abalama
Champion C63YC (#796) FTW.
Iridiums and long hard pulls don't like each other. I do believe that sub 500rwhp levels are fine for Iridiums, just get a step colder.
Copper displaces heat better. Sure, you have to change them out every other oil change, but they work the best IMO.
tissimo
Stock is boring :(
Melbourne, FL
my buddy has iridiums in his bpu 1j.. and it was detonating with them.. I'm not sure on the heat range he used, but he switched to 3330s and it went away and hauls ass now..
