sp61gt on 1jz
johnverheij
shoarmateam member
Nov 21, 2006
64
netherlands
my question
i have a sp61gt (61 wheels) in stock with 2300km on it
came from my 7m.
can i have some fun with it on my 1jz
with the driftmotion ct26 exhaustmanifold
SuprA70
SF.com 'Grounded' Champ
There are clearance issues with the shock tower. The ct26 housing already sits incredibly close, anything bigger will not fit, so the Driftmotion adapter manifold will not work. You would have to get a dedicated 1JZ exhaust manifold for that turbo.
Tim
regular member
Oct 16, 2006
272
CA
honestly, I had the ct26 manifold kit from Driftmotion and I think that the SP61 would fit, but it will be damn close to the shock tower, possibly touching it. A big shot with a sledge hammer could fix that though:biglaugh:
SuprA70
Maybe. You can drop the engine with the turbo already bolted on and MAYBE clear.
Good luck pulling that turbo off (sp61) with the engine in the car. The studs on the manifold are too long, you wouldn't be able to move the turbo to clear the flange, much less install the turbo with the engine in the car. Even unbolting the manifold from the head will not work since there's not enough clearance.
Barely any clearance with a ct26. Imagine something with even just a slightly bigger turbo housing.
johnverheij
shoarmateam member
Nov 21, 2006
64
netherlands
i have a t3 1jz manifold
not bolted on right now still driving the twins
so where do i get a ct26 flange?
this is what i have in stock
[/URL][/IMG]
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
suprarcr89 said:
^he would also have to have a block off plate for the wastegate flange.. as the sp61gt has an internal wastegate....
He could ship out the manifold to get a new flange welded on, and at the same time get the external tube chopped off and closed up.
Tim
regular member
Oct 16, 2006
272
CA
I have that exact XS t3 manifold as in the picture now with a 60-1 and the hood basically rests on the turbo. I personally think that their will be now room for a t3 ct26 adaptor with the xs manifold. You might have better luck with another manifold that sits lower.
