Solder or Crimp - [injector clips]
p5150
ASE and FAA A&P Certified
Central Idaho
depends on the connection im using. If subject to flex and stress I prefer crimps with heat shrink. In most cases though I prefer solder with heat shrink extending at least one inch down from each end of the exposed portion.
silvergsx623
WIPLSH & HWY KNG
Oct 16, 2005
498
Alabama
isnms said:
I'm going to install my Lex and 550's this weekend when I replace my intake manifold gasket.
Which is best method of splicing in the new injector clips?
Solder or Crimp
Crimp
Solder is not good because of vibrations :3d_frown:
I twisted my injector wires together and then looped them together, soldered them and then shrink wrapped them, then electrical taped them together. So far so good. If I had read this before I soldered them a month ago, I probably would have went with crimping them instead.
2543arvin
Moving to Japan!!!
Nov 30, 2006
879
Jacksonville, NC
I crimped mine and wrapped them with electrical tape, so far with 2000 miles, no problems, but since I havent had them that long I cant speak on reliability.
Dr Tweak
Being a subject that I've done extensive research on and feel pretty strongly about, I will comment.
I used to be a big solder advocate for some time. After doing more research into it (and wiring taking center-stage in my business), I found that soldering is not the best method. (It was actually while reading Jeff Hartman's excellent book, How to Tune and Modify Engine Management Systems, that I first learned about this. He mentions that shops like Norwood Autocraft (land speed record MR2 builder) uses crimps over solder. After that I decided to make a more thorough investigation of the matter).
Consider:
The Motec install manual says:
Soldering a terminal is a last resort if the proper crimp tool is not available. Soldering will cause a stress point where the solder wicks up the wire which is likely to cause a fracture. Solder flux can also cause corrosion and may affect the contacts.
The AEM manual:
The preferred method of securing a wire to a terminal is to use a crimp with NO solder.
A company that makes race car harnesses:
The procedures for automotive wire harnesses vary, however, I'll narrowly comment on building a wire harness for a racing car according to the MilSpec guidelines for airplane harnessing. There is almost never, ever a time where soldering is acceptable. When you solder, you create a joint where the wire which is flexible meets with an inflexible joint and eventually, due to vibration, the wire will become fatigued and break. I crimp everything and use a proper strain relief which can be as simple as a glue lined shrink tubing and a small zip tie.
Not mention the best evidence of all, Toyota (along with every other manufacturer that I know of) uses crimps and NO solder anywhere in the harness.
Now, something that's VERY important that needs to be brought up is WHAT KIND of crimps we're talking about and WHAT KIND of tool you use to crimp them. When I say "crimp", most people picture in their heads the plastic insulated butt connectors that you buy at Autozone or whatever and squeeze together with a wire stripper tool. Those are NOT the type of crimps that professionals use.
Mil-spec crimps are non-insulated (heat-shrink tubing is used after the connection is made), typically made of tin-plated copper. They come in several sizes and the right crimp must be used for the right size wire. Then the crimping tool, with the matching die is used to make the connection. The tool has a ratcheting mechanism, so EVERY single crimp is made using the same amount of pressure EVERY single time. The ratcheting tool also helps to put more force into the crimp then otherwise possible.
As you can see, a lot goes into making a good crimp, and the results are fantastic. However, for the "average" car-owner doing some limited wiring, it is probably not going to be cost-effective to invest a lot of money in the crimping setup that I just described. In such a case, soldering (using the proper technique!) will probably be preferred. There was a question earlier in the thread asking if someone had actually seen a problem with soldering or just read about it. To answer that, I have a number harnesses come into my shop that have been soldered by someone before they came to us (for example, some people extend their 1JZ harness before they learn about our service, and we get it after it's been cut and extended). On almost every occasion, there were at least 2 or 3 otherwise well-soldered connections that had broken because of movement (not to mention the bad connections that were still hanging on by a strand or two). That's why we have to crimp all the connections on the harness in order to maintain the warranty.
We make all of our wiring harnesses using crimps, as we have for the last two years or so. With over 150 plug and play conversions on record, we haven't yet seen a more reliable method of making wiring connections.
I hope that helps! :)
-Doc
quake
toyota tech
Apr 13, 2005
619
r.i.
whenever we have an electrical problem at toyota, the first thing the tech looks at is for any aftermarket install and 8 out of 10 times you find a short in the harness caused by crimping, but connectors, wire twist with electrical tape and so on. We fix by soldering and heat shrink. If the car comes back were working for free. Needless to say it never comes back
p5150
Central Idaho
Yeah quake I think that goes back to the type of crimp connector used. I do know that on aircraft solder is used very rarely and many things are crimped - just with a different tool and quality connectors
7MsuprO
322
Huntington Beach CA/Ohio
-Doc
Link to said tool? I'm interested to know.
quake
toyota tech
Apr 13, 2005
619
r.i.
agreed
