Here it is folks, a list of power levels that will actually be updated.
To go with our 1/4 times list, we will now have a list of the top dyno results for 7M, 1J, 2J and "other" Toyota powerplants. We DO want to see the posted sheets but, if possible please include a direct link to the graph, or a thumbnail of the graph to help keep the thread a bit cleaner. Thanks!
There will be 4 sections. 7m powered, 1j powered, 2j powered, and Other - ie, 5m, 1G, 1/2uz, etc. I will do top 30 for 7m powered, since that is the majority, and top 15 for everything else.
Edit by Grimjack: Slight change - you still need to be able to get into the top 30 / 15 to get on the list, but I won't remove people who get pushed down past the bottom.
Make your submission by posting the following:
Let the games begin.....
7M-GTE powered
1JZ-GTE powered
2JZ-GTE powered
"Other"powered (1UZ, 5/6M, etc.)
- Your corrected wheel horsepower and torque.
 - Engine type.
 - Dyno sheet or video. I will work on the honor system that it is actually yours.
 - A *basic* mod list. Preferably ones that affect your power levels - save the details of your color shifting paint for a different conversation, please.
7M-GTE powered
- mibrum - 1340whp - 91mm turbo, 40psi, stock crank and block, pauter rods, JE pistons, Jerico 5spd, 1mm oversized valves, ferrea valve train, ported head, TEC3r standalone
 - Elli - 885whp/657wtq - BC272° Cams, BC Springs, JE-Pistons, Eagle Rods, S475SX, EMS8860
 - upgradedsupra - 853whp/642wtq - JE's, TI rods, OEM crank, head work, custom TED billet cams, MoTeC M600, MoTeC E888, MoTeC SKM, M&W ignition, AIM DD, Weldon 2345, RC1000's, ATI TH350, Moly driveshaft, Custom ATI crank damper, Ron R FFIM.....
 - kwnate - 842.98whp/683.20wtq - gt4067, AEM, ported head, TED 268 cams, Ron R. FFIM, aeromotive pump/1000's, tilton triple carbon/carbon, w/ n2o
 - toyotanos - 788whp/674 rwtq - 7M Eagles/83.5mm JE's, AEM, 1350's, E-85, Billet 6765 @ 31psi, +1mm valves, dual springs, P&P, BC 272 cams
 - X-man - 753 rwhp/589 rwtq - stock internals, gt42 @ 30 psi , 1000's, aem
 - MK3Brent - 641.24whp/574.20wtq - GT4088, walbro/550s, VPC/AFC
 - mark1987supra - 618whp/571wtq - 7MGTE, PROEFI, E55, SP61, 25 psi, 1200cc inj., BC 272 cams, Weisco 20 over, Crower rods, Hks Stopper, ARP Head and main studs.
 - NashMan - 585whp/540wtq - PTE 67mm @ 24psi, BC272s, 850cc injectors, microtec lt10, a1000 fuel pump
 - mytmk3 - 566.58whp/929wtq - Mp t70, tial v44, Toda cams Titan cam gears, comp cams valve springs, Je's and eagles, 1200cc injectors + dual walbro's, 3.5" catback 3"downpipe 2.5"&3" ic pipes large fmic, Ffim q45 tb, Link g4 ecu, Os triple plate clutch
 - Supra8795 - 551.12whp/472.39wtq - mp T70, 750's, single walbro, afpr, , 3" exh., 4" intake, VPC/AFC, port/ polished head, 272 cams, Ron R ffim, 4" xspower ic, stock bottom end, cometic hg.
 - HKS_TRD - 540whp/XXXwtq - GT35R, Motec M800, UNPORTED HEAD, HKS Cams, Greddy Intercooler, Stock intake manifold, Turbo A throttle body
 - BostedSupra - 531whp/XXXwtq - AEM, SP63, 40 over JE's, Crower rods, stock crank, webcams 244, stock head, SP manifold, SP down pipe and mid pipe, apexi GT-spec cat-back, aeromotive 1000, greddy 660cc, apexi 3 row innercooler
 - teamslow - 526whp/475wtq - Precision 6765 journal bearing turbo.81A/R 18 psi on pump gas, ID1000cc injectors, Walbro 400, AEM
 - tekdeus - 515whp/503.4wtq - 28psi, stock 7m with MHG, 62mm billet HTA3586, SAFC, Lexus / 550s, water / meth injection
 - mytmk3 - 515whp/435.4wtq - Mp t70 tial v44, Toda cams Titan cam gears, comp cams valve springs, Je's and eagles, 680 injectors + single walbro, 3.5" catback 3"downpipe 2.5"&3" ic pipes large fmic, Ffim q45 tb, Link g4 ecu, Os triple plate clutch
 - supra90mkiii - 513whp/455wtq - 11.6:1 afr, sp61gtbb, ported head, bc 264 cams, ffim, 680cc injectors, 24psi, factory untouched ex manifold.
 - polobai - 510whp/466wtq - Built 7m, (wiseco pistons, eagle rods, etc.) Port and polished head, three angle valve job, 272 bc cams, valve springs. Gt4082 at 20psi with 550's +meth on 93 octane. Maft pro @ 11.5 afrs.
 - topgear - 505.3whp/527.4wtq - MP T70, walbro/1000's, Ported head w/3 angle valvejob, Eagle/Weisco combo, HKS Stopper 2.0mm, Fidanza Flywheel, RPS Bronze Stage 5, custom mani and exh., BIC IC, AEM
 - jonny87turbo - 500whp/443.4wtq - 20psi, 7mgte with comp vrp64mm bolton turbo, 3in exhaust, 40 over with cp pistons, snowperformance meth injection, 2.5in intercooler piping, DM intercooler, AEM EMS, 1000 ID injectors, dual intank walbro fuel pumps
 - MarkIII4Me - 467whp/426 ft/lbs - *JE Pistons * Crower Rods * Crazy Head Porting * Custom Raised 7M turbo Cams * ARP Head Studs * HKS Stopper HG * AEM Cam Gears * Turbonetics Hi-Fi 62-1 Bolt-on Turbo * 5" Blitz SUS Filter * 1JZ FFIM w/ all provisions * Delta Fin Intercooler * Greddy 720cc low impedence Injectors * Aeromotive AFPR * Tial Q Bov * Trust Power Extreme II Exhaust * BIC Ceramic DDP * Fluidyne Radiator * Flex-a Lite Fans * Spec Stage3 Clutch * AEM v1 Rev.B Mod.C EMS
 - yota8791 - 461whp/411wtq - je's, stock rods, HKS 2mm MHG, P&P head, garrett T67 @17psi, hks intake, ets 32x12x3.5 fmic w/ greddy pipes, Sard FPR, walbro/870cc bosch injectors, ACT stage 3, 3" elbow/dp, HKS super dragger
 - survyor2 - 440.6whp/431.0wtq - sp61 kit, HPF ic kit, je/eagles, 3"exhaust, spec3, fidanza flywheel, 550cc, lex afm, safc2, avc-r
 - gixxer750 - 432.09whp/XXXwtq - t66 @ 15psi, FFIM, aem
 - wardog - 431.74whp/426.47wtq - ct26/60-1 @ 18psi, K&n, maft pro, ddp, 3"exh, walbro/550's, 2.5 hardpipes/FMIC, evcEZ ,safc2
 - suprakid24 - 431.23whp/441.91wtq - GT4088r @ 18psi, AEM ECU, 750's, HPF IC, stock internals
 - aye mate - 430.91whp/390.50wtq - SP61GT,stock bottom end, 3" Exh, Walbro/stock injectors, Lex AFM, FMIC w. 2.5 hardpipes, 2mm cometic/arp's, Spec Stg 2 Clutch
 - crisp - 427.14whp/368.22wtq - HKS alphabet soup on 550cc injectors off a single Denso MKIV pump, stock bottom end, 17.6psi
 - pln - 425.3whp/XXXwtq - gt35r @ 18psi, mapecu2, rc550, mid-ported head
 - UberSupra - 423.16whp/401.67wtq - SP61GT, Stock Bottom End , 3" Exh, Walbro/550cc/Lex AFM, Spearco IC w/ 50mm Hardpipes, Spec Stg 3 Clutch
 - Fuzz420 - 422whp/401wtq - 17psi, Rebuilt GTE, Probes, prepped rods, ARP, HKS MHG, stock head, JT56 Turbo, RC550s, Wally, Aeromotive FPR, Maft Pro
 - 92nsx - 417.41whp/382.81wtq - 40 over probe pistons, eagle rods, HKS MHG, BC 1mm oversized valves, BBC springs, BC 272 cams, A1000, afpr, Lexus / 550s, FFIM, BOSS Sr. - P-trim 61mm, GTS housing triple ceramic ball bearing turbo.
 - sunnysupra - 413whp/475wtq - stock head, crank, rods. JE 20 over. hks HG. stock upgraded ct26. walbro, vpc/afc, spearco intercooler
 - paradox616 - 411.5whp/379.6wtq - stock rebuilt motor, cometic/arps, 3 angle valve grind, T61 @ 16psi, 3" turbo back exhaust, haltech e6x, 835cc injectors, walbro 255, 24"x12" intercooler
 - kmfdmk - 406.63whp/392.33wtq - 57 Trim CT-26, 550's, Maft-Pro, Tial 50mm, 2.5" IC, 3" full Exh. 12x3x36 FMIC, Probe Pistons, Eagle Rods, Knife-Edged Crank, XTD Lightweight Flywheel, Stage III Clutch, P&P Int. Head & Exh Mani. Dual Oil Filter w/ Oil Cooler & Thermo. Crank Scraper
 - soup - 405whp/391wtq - rebuilt 7m w/stock internals, mhg w/arp studs, lucas pte 580's, lex afm, greddey eman blue, basic harness, t4 60 trim / t3 .58A/R hot side at 14psi, BIC tube manifold + 3.5" exhaust, NPR intercooler
 - Supra0089 - 402whp/408wtq - JT62 turbo at 16psi, HKS MHG & ARPs, RC550s, DDP, 3" exhaust, Spearco FMIC, Wally, built a340e
 - KevinM - 391.36whp/378.69wtq - SP63 @ 17psi, MAF Translator, 720cc inj, SAFC2
 - pimptrizkit - 375.49whp/334.84wtq - 57 trim ct26, 2.5" hard pipes, fmic, stock injectors/pump, n/a cams. full 3" exh. no cats, rebuilt head, .20 over, 2mm mhg, stock rods, MAFT Pro
 - sethron71 - 372.47whp/363.32wtq- 57 Trim CT @18psi, Lex AFM, Walbro/550's, S-AFC, K&N, Divorced 3" DP, Full 3" Exhaust, Long Runner FFIM w/ 3.25" TB, FMIC and 2.5" IC piping, 2MM MHG w/ ARP's, Fidanza w/ SPEC Stage 3+, One-Piece driveshaft
 - CajunKenny - 367whp/345wtq - JT62 @ 15 psi, PTE550's, Walbro, AFPR, Maft-Pro, Fidanza FW, Fan Delete, Extrude Honed Intake Manifold, DM IC, 2.5" IC Pipe, Blitz Elbow, 3" SuperDragger, Test Pipe
 - rodel - 365.6whp/373.4wtq- aem ems, 60 trim ct26, 550 injectors,3" exh.
 - avp23 - 364.18whp/373.94wtq- je pistons, eagle rods, light flywheel, spec 3+ 60-1 trim, 550cc, lex afm, big fmic, 3inch exh. afc, avcr.
 - tsupranami - 363whp/- 1.0 BAR, untuned, stock internal 7M-GTE, Boss Sr. 57 trim, 550 injectors, LexAFM, Apexi SAFC and AVC-R
1JZ-GTE powered
- Albert - 722whp/618wtq - 30psi on stock block 1jz. 1200cc, e85, dual 044, T70 turbo. .84ar, 3"dp, 4" exhaust, 272 cams. 20° timing. Tuned by tony at UMS on Proefi 128
 - 525gte - 641whp/500wtq - 30psi stock rods. Cp 9to1 pistons. 1200cc e85 precision 6262. 82 ar bc 264 cams ms3 pro single aem320 in tank pump.
 - 2JZ_MA70 - 602.6whp/550.8wtq - stock motor GT35R-HTA, 3" turbo back, Tub manifold w/ 60mm tial, 24x12x4 Int, 1600cc, Twin Walbros, AEM EMS and C2DI
 - Turbo Drifter - 550.7whp/~460wtq - IHI RHC7 20p @23psi, 550's, S-AFC, BCC, 3" exh & dp, Spearco 24x12x3.5 I/C
 - suprahero - 543.2whp/437.3wtq - gt35 @ 24psi, 3" exh, crower 272's, DM FMIC and hardpipes, Stinger, walbro/624's
 - 10secdream - 482.46whp/406.03wtq - Jun 264/272cams, Bosch 044 fed by stock pump, MK4 550s, Apexi IHI C7 Turbo @ 22psi, 3" dp/BIC 3.5" Catback, Devils Own Meth Inj kit w/ M14 nozzle, Stinger EMS, ARC 18x12x4 IC w/ 2.5" piping
 - Torque - 471.78whp/381.94wtq - stock 1jzgte motor, sp63 turbo, 3 inch turbo back exhaust, 24*12*3 inch intercooler, 2.5 inch intercooler piping hot side and 3 inch cool side, SAFC, MK4 550cc and walbro in-tank fuel pump.
 - Yotaholic - 451whp/390wtq - HKS twins @ 19psi, Spec Stage3+, Raptor Racing 3" ss Exhaust w/HKS Y pipe, 24x12x3.5" IC, Emanage Ultimate, Bosch FP/sard 650's, Mines Ecu, usdm 2J cams, Titan adj cam gears
 - becauseican - 449whp/410wtq - USDM 2jz custom machined cams, MK4 pump, BIC top feed rail w/750's, DBB SP61 .58 a/r, BIC custom 3.5" DP/Thunder catback, Haltech PS2000 EMS, AEM water/ Meth kit, Garrett/ Spearco custom 24x12x3.5" IC, BIC custom 2.5" IC piping
 - honestabe - 399.95whp/346.54wtq - Driftmotion 60-1 .70 A/R twin scroll turbo @ 16psi, DM twin scroll manifold, 3" turbo-back exhaust, SAFC NEO, JDM 2J 440cc injectors, CAI, FMIC, 2.5" IC piping
 - Viggs - 392whp/331wtq - DM67 kit, 93+meth, BC 272 cams, 780cc top feeds, dual walbros, cracked coil packs
 - lazer1100 - 380.9whp/418.1wtq - Stock 1jzgte , rebuilt twins at 18psi, mines ecu, SAFC 2, full three inch fencepole and turbosmart manual boost controller
 - destrux - 369.5whp/388.1wtq - Stock 1JZGTE, Holset HY35W on tubular manifold, 46mm wastegate, 3" intake w/ K&N, 3" turbo-back exhaust, 100cell metalcat, Circuit 7 MBC, 2.5" IC piping, JDM Sport 3" Intercooler, AFC Neo, 440cc injectors, Walbro 255 HP, vF gauge, PLX wideband, SSI-4 datalogger
 - brett - 346whp/290wtq - GT4082 .86a/r @ 11psi, 440's, Crower 264's, S-AFC, Aeromotive AFPR, Dual Walbro's, RPS Max 6-puck
 - Zerocool - 331whp/299wtq - T66, 3inch exh, FMIC w/ 3" hardpipes, SAFC II, JDM MKIV 440's, Walbro 255
 - te72 - 320.45whp - 89 Supra, 1jz, stock twins @12psi, BC264 cams, ported/polished, 3" exhaust from turbos back. Stock AIRBOX.
 - viperkillertt - 300.6whp/298.7wtq - Stock Twins@15psi, 12x24x3" ic, Blitz ecu, Full 3" exhaust w/cat & Y-pipe
 - MK3Hitman21 - 300.54whp/310.06wtq - Completely stock 1j, with emanage blue and boost controller.
 - sixpatch - 297.57.5whp/319.98wtq - AEM wideband, SAFCII, AVCR, Driftmotion IC & hardpipes, Wally, Koyo rad, Southbend Stage 4 clutch, 17.21psi
 - xsjado - 292.5whp - stock twins@12.7 psi, 2.5" y-pipe to 3" exhaust, 24x12x3 FMIC, Malpassi FPR, SAFC-II, AVC-R, Single plate clutch, Titan Cam Gears -5 exh/+1 int
2JZ-GTE powered
- 2jzmk3 - 1037.1whp/XXXwtq -
 - jt2ma71 - 844whp/646wtq 26 psi. Dry sumped. Ron R. intake manifold, Ron R. exh manifold. Ron R. 4" exh w/ burns muffler. GT42R. MoTeC M820, MoTeC CDI8, MoTeC E888, MoTeC ADL, MoTeC TCMux, MoTeC etc.
 - nathaninwa - 778whp/636wtq 26psi, MS3Pro, Wiseco 9.5-1, K1 rods, S1's, 6466 divided .84, staged injection with 1200cc secondarys on A1000-116 race gas.
 - mrsuprafreak - 716.94whp/686.39wtq - Borg Warner 80mm Stock block and stock head 272 HKS, 850cc injectors, 4inch Custom exhaust.
 - hottscennessey - 677.86whp/580.17wtq - 2JZ-GE NA-T; Master Power T70 .68 A/R., Bosch 044, 870cc injec
 - rodel - 668whp/615wtq - Stock vvti 2jzgte, 67 Comp Turbo, 1000cc injectors, 25 lbs boost, e85, aem v2.
 - Nick Stonawski - 619.78whp/523.49wtq - T88-33D, 720s, hks 264's, Exedy twin plate clutch, g-force ECU
 - suprahero - 614whp/561wtq - 1j head, pt67@25psi, 3" dp to 4" exhaust, SARD 624cc inj., BC 272 small core cams, CP pistons, Eagle rods, DM IC & piping, Drewgo mani, Tial 44, meth inj, Stinger EMS, Apexi AVC-R, Stock intake, HKS DLI
 - Nick 95 6sp - 613.8whp/590wtq - 22psi, water / meth injection, Twin Garrett GT2860's with Tial exhaust housings on V-band moded HKS manifolds
 - SirLoki - 609.72whp/541.36wtq - AEM ems, HKS t04z, HKS 264's, 720's
 - leecheater - 579.7whp/588wtq - GT3582r DBB, US OEM cams, 24x12x4 IC, , Aeromotive FPR and fuel pump, HKS replica 50mm WG, Greddy SP Cat Back, 1pc jawsgear Steel Driveshaft, 1200cc injectors, AEM ECU, tuned with E-85
 - Grimjack - 578whp/557wtq - 5 speed, dbb 67mm turbo, 890cc injectors, water meth, Vipec v88
 - dok33 - 533.1whp/496.93wtq - 93 2jzge, TT hg, 7M ECU/Harness, Lex AFM/SAFC, 880cc inj/E85, SSAC T4 Manifold, MP T70, 50mm wg w/ 15psi spring,Aeromotive FPR, Bosch 044 pump,Chinese dp to 935 3" DIY exhaust
 - jmcboost - 533whp/461wtq - 2JZGE-T, 1.8MM HG, Master Power T-70, Stinger 4424 EMS, Web cams 264, R-154, 780cc, Wally, FFIM
 - NewGen - 516.74whp/436.12wtq - 2jzgte Stock Engine, Chinese gt45, AEM V2, 91 octane @18 psi
 - Torque - 420whp/404wtq - Borg warner 83-75 turbo, Cast manifold, 3" down pipe to a 3" Greddy SP cat-back exhaust, Sard 800cc injectors, Walbro 400lph fuel pump, 12x24x3 intercooler and a AEM V1 EMS.
 - gurley0916 - 417whp/397wtq - Aristo 2jz-gte, R154, 3'' Exhaust 4'' Intake, Garrett 67mm turbo with .70 divided housing & manifold, usdm 550cc injectors, MAPECU tuner, Lc-1, Walbro 255, Dyno was at 19psi
 - tissimo - 394.91whp/389.76wtq - Stock twins, 18 psi, fmic, 3" exhaust
 - bigdaddygrip - 392whp/330wtq - 1j head, 264 BC cams, 550's, T67 turbo .58 a/r, Map-Ecu 2, 93 octane + Meth
- darkspeed - 421whp/401wtq - 6m, T61, 3.5" DP, HKS mani/40mm WG, Megasquirt EFI, walbro/720's, FFIM w/ ford tb, spec stg 3, npr IC
 - limequat - 249whp/259wtq - 4.2L VORTEC swap (inline 6, aluminum block), 3" exhaust and custom tune
