***SM Member Horsepower List***
Definately needs a tune Aaron, but congrats non the less. George didn't make as much as you and he has a t67. I tuned it, which could be the problem, but he only made 409 @ 17 psi. His pull lots a lot cleaner than yours which is why a tune will help you out a lot. Good luck.
Torque
255
In your home
I just dynoed 471hp and 402 lbft of torque at 23psi. Mods were entirely stock 1jz engine, a pt63 turbo, 550cc injector, 3 inch turbo back exhaust, drewgo manifold, and 2.5 inch intercooler piping hot side and 3 inch cool side.
bigdaddygrip
148
Omaha
392.whp 330wtq @ 14psi 1.5 jzgte 264 BC cams 550cc 2j injectors 93 octane + Meth Map-Ecu 2 T67 turbo .58 a/r
Special Thanks goes out to Jay/Suprahero, slo_sc3, Zazzn, Arron/ driftmotion, and David / Evan PolkPerformance
[/IMG]
gixxer750
2jzget comingsoon!
Mississippi
HalsupraMK3 made 522 whp at tx2k10 at 23 psi with the car breaking up badly from old/gapped too big plugs. Changed the plugs later at the track and ran 25/26 psi and it ran much better.
Waiting on peter to post the dyno graphs and I will post here for Hal when I get them. Car has a SP Billet 71, BC cams, wiseco pistons, stock rods and AEM. Its my old 7m from the burgandy car I had at TX2k8, and the internals haven't been touched since. Engine has 50K miles on it since build.
http://www.youtube.com/watch?v=pDMgbo2pRgY
http://www.youtube.com/watch?v=mmW3z0HyagA
Hal Mcdonald, left hand side.
Boosted Supra
AEM 7MGTE 6765
Apr 7, 2005
353
Valley Stream, New York, United States
This is old but current
531rwhp @21psi, no torque rating. AEM, SP63, 40 over JE's, Crower rods, stock crank, webcams 244, stock head, SP manifold, SP down pipe and mid pipe, apexi GT-spec cat-back, aeromotive 1000, greddy 660cc, apexi 3 row innercooler
isnms
United States of America
Oklahoma
i80.photobucket.com
318HP/364TQ, 15psi
Mods:
• k&n fipk • cartech ic series 2 • defcon ic hardpipes • bosch 110 & blitz ss • lexus afm • pte 550 injectors • ct26 50trim no clip • becauseican 3"dp • exhaust depot 3" high flow cat • raptor 3" cat back • magnaflow 12198 • arp head studs • cometic mls • je pistons • crower rods • clevite bearings • ngk plugs • msd 8.5mm • ati super damper • spec stage2 clutch • fidanza aluminum flywheel • mkiv-tt fuel pump • aeromotive afpr • hks tt • hks evc iv • greddy rebic lc cpu-ii • zeitronix zt-2 • g-tech pro rr • prosport fp gauge •
I still have some room to improve. My made my street tune for around 11A/F but on the dyno it dipped deep into the 10's.
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
^You've got a little room for more power; but, hey.....10's are safe!
I like seeing how the AFR's affect the EGT's. I wish I was setup to log EGT's. :(
I'm headed to the dyno on the 28th. I'll be looking to reclaim a spot on the list. ;)
isnms
Oklahoma
i80.photobucket.com
I didn't do any tuning on the dyno, just two runs for results. I did my street tuning for low 11's. It showed richer on the dyno.
Good luck on your session. My results should get me into 24th spot :D
paradox616
472
Melbourne, Australia
411.5rwhp (306.9rwkw) 379.6ft/lb (514.8nm)
7mgte, more or less stock rebuilt motor, cometic/arps, 3 angle valve grind T61 @ 16psi 3" turbo back exhaust, haltech e6x 835cc injectors & walbro 255, 600x300 intercooler
on boost its about 11.8:1 afr
CajunKenny
Nov 15, 2007
3,255
Washington
Here's mine from today. 367 HP/345 TQ. Something started to break-up at 15.5 psi so I decided to stop. There's more to be had; but, this will get me back on the list. :)
Engine: 7MGTE
Mods: JT62 @ 15 psi, PTE550's, Walbro, AFPR, Maft-Pro, Fidanza FW, Fan Delete, Extrude Honed Intake Manifold, DM IC, 2.5" IC Pipe, Blitz Elbow, 3" SuperDragger, Test Pipe.
toyotanos
What will we break today?
2,844
Coon Rapids, MN
paradox616
472
This list needs updating :p
---------- Post added at 09:24 AM ---------- Previous post was at 09:22 AM ----------
toyotanos;1581198 said:
Just got off the dyno today, made 408.1 hp, 386tq at 17psi on a dyno dynamics unit. Using 92 pump gas on my 7M
[THUMB]http://i432.photobucket.com/albums/qq47/toyotanos/1991%20Toyota%20Supra/DSC00217.jpg[/THUMB]
Mods- LIPP Boss Sr. 61mm p-trim TBB turbo, greddy 720's, mk4 TT pump, afpr, 2.5" hardpipes, 3" IC, tanabe hyper medallion, test pipe, divorced downpipe, custom FFIM, AEM EMS, AEM tru-boost, built bottom end, spec stage 3+ clutch.
Interesting, Near identical set-up and very similar numbers, torque and hp.
toyotanos
2,844
Coon Rapids, MN
Indeed- I thought the same thing when I got back that day. How thick is your I/C? Mine is only 3" but I will be running E-85 soon. Tuner says there's 50HP in timing alone pulled at this boost, let alone the fact I can run more boost and we can lean it out a little more (running 11:1 right now, just for safety).
CajunKenny
Nov 15, 2007
3,255
Washington
Once this gets updated, one will have to be at around 350 hp minimum to get on the list. Raising the bar baby...raising the bar...! :D
