sm almost completed, need info on error tho
suprra_girl
7M POWAH! ;)
Auckland, New Zealand
www.supra.co.nz
so i've almost finished the install of the super monitor and found the mounting is a bit low so you have to lean up to see it... that i can fix hehe
but when i try to do diagnostics it just comes up error.. any ideas?
thanks :D
suprra_girl
7M POWAH! ;)
www.supra.co.nz
so i've tried various combinations...
hold set & m at the same time
hold set then m
and held for longer than 4 secs but still doesn't switch to diag only displays error
*sniff sniff*
i guess i'll be chasing the T wire tomorrow making sure it's on the right wire
suprra_girl
7M POWAH! ;)
www.supra.co.nz
OMG... i deserve the dumbass of the year award!
it actually pays to turn the key to ign for diagnostics LOL
so i got code 24 (no afm that's fine)
code 41 and 51 (tps hmm, it's not hooked into the throttle body properly but as long as the wires are connected it should be all good right? So do i need to check my wiring? I did extend the harness to reach the new tb)
Oct 11, 2005
3,821
26
Thousand Oaks, CA
For the ECU and ECT, the supermonitor will set the diagnostic mode automatically (It has connections to the TE1 and Tt diagnostic pins of the two ECUs). For cruise and ABS, you have to do it manually. If you look at the wiring, you will see that the only connection to the Cruise and ABS computers is the dash warning lights, and they are outputs, not inputs. So for them, it is just a glorified flashing light counter.
