Slow Spool & Chugging
robbo185
693
Chicago
stock bov's i remember dont work as well when you hit a certain boost....and with an upgraded turbo this may be the case
N
NDBoost
Guest
i can test it with my Type S but it had the issue w/ the Type R.. before the stock BOV
Timmer
34
Canada
NDBoost said:
jdub all of those gaskets were replaced, the ONLY thing that i could think aside from fuel related issuse would be his IC and IC piping.. other then that.. nothing
shaeff as stated no codes present.
Have you done an i/c and piping pressure test? You can never assume that they aren't leaking from how they look.
ericshere03
27
Phoenix, AZ
How do you do that? remove the hoses from the turbo and cap one side and blow throught the other?
tissimo
Stock is boring :(
Melbourne, FL
make sure the tps is set properly.. sounds like timing is retarded.. When i first got my car running i set the timing to 10 in the manual but tps wasn't set right and was actually set at -10 to -15*
still ran a 16.3 at 83... fixed the timing 15.1 at 91..
T34418L3ONE
Supra for brains.....
Jul 3, 2005
225
Pleasanton
check for vaccum leaks, also what is the idle? choppy, smooth, what rpm? Id do a fuel filter in case the previous owner ran crappy gas and clogged it up.
Timmer
34
Canada
How I've done it in the past is to cap the compressor inlet on the turbo via a piece of rubber and a worm gear clamp, then get a pcv,abs, or other cap and drill a hole in it to fit a regular tire valve stem. Clamp the cap with valve stem onto the other end of your i/c piping and then pressurize with a bike pump or compressor if you have one. That will test all of your pipes and your i/c, but will not tell you if you have a leak at the manifold/throttle body area.
ericshere03 said:
I am the Owner of thhis PIECE we are talking about, it seems like my EGT's are throught the roof at my ENTIRE exhaust side of my turbo glows red after driving for 20 min on the freeway, driving nice too. So my plan of action would be to replace the fuel filter and swap Injectors. after that ill take the damn thing to toyota for a computer diagnostic.
BTW: i get 16MPG city, freeway combined.
Clogged Cat?
N
NDBoost
Guest
Alright just a little update on this issue.
Swapped out the injectors with known working stock 440cc injectors and the issue is still present. Turbo is still glowing red w/ stock heatshield and casual (no boosting) driving to and from work(15-20min drive).
I am still on the hunch its a fuel related issue, but the low vacuum is what throws me off. I tried making plans with my friend (ericshere03) to see if we cant swap his IC and lines out with some off of my car to test. Fuel filter will also be replaced.
If anyone has any bright ideas on anything else to test please let me know.
MDCmotorsports
Indy 500
www.MDCmotorsports.com
Timing all the way. Sounds to me like the exhaust cam has slipped and is letting raw exhaust out into the turbo. This is why it is sluggish to do any thing and you're seing egt's out the yang.
Also, sounds to me that if the ignition or the cam timing isn't off, that SOME WHERE there is a massive boost leak that you just aren't seing.
Take the IC to a radiator shop and have them pressure test it.
N
NDBoost
Guest
With the timing cover off and the crank set to 0 degrees BOTH cam gears are at the proper top positioning mark. So unless the pins arent in the right position i doubt the cam timing could be an issue. The IC could have a leak, but TBH he would probably end up buying a new IC from ebay that mounts up like stock rather then getting the stock one pressure tested etc. The only TRUE Boost leak i can think of would be the inner fender hose thats plastic, we cant see it easily and havent really looked at it. However the lower IC pipes do appear to be in good shape, but no physical pressure test has been performed on them.
How do you go about making a pressure test tool for our IC pipes?
MDCmotorsports
Indy 500
Go to your local home hardware store and buy some pvc caps that fit into the boost hoses.
Take the turbo hose off and plug it. Take the throttle body boost hose off and plug it. Insert a valve stem into that plug. Take an air chuck attached to a bicycle pump or air compressor compress the system. Have a bottle of windex or soapy water near by and spray every boost connection possible. Also listen for leaks. I'm betting that since the timing is right on, that you have a massive boost leak. Extremely excessive fuel causes high egt.
N
NDBoost
Guest
Can you just hookup the pvc cap thats tapped w/ the fitting to the turbo and then cap off the 3000 pipe and test all of that? or do you ahve to cap off the lower IC hose that connets to the turbo?
N
NDBoost
Guest
yeah we replaced taht after doing the plugs and wires and intake side gaskets.
Hes going to perform a pressure test on it and see what happens.
N
NDBoost
Guest
as a matter of a fact the analogy we/he used for the firing order got mixed up, we got it as 16 35 24 instead of the proper order of 15 36 24. Hes going outside on his lunch break from work and testing it to see if thats whats causing issues.
He doesnt missfire and he has a steady idle... strange hopefully this is the issue.
